3.2 Pinion Will Not Slide On Third Motion Shaft
Best Answer Aridgerunner , 08 May 2025 - 04:15 PM
Fixed it!
My brother had a very fine half round diamond file. Meant for filing diamonds. I applied the red dye to the gear and pushed it on as far it would go, which isn't much. Then I lightly, and I mean like removing just the red dye, and then tried fitting the gear again. After the repeat process I filed again and now it fits perfectly. It's a bit tighter than the 3.44 but I can now push it on by hand. And it does clear the bearing retainer.
Thanks again!
Bill Go to the full post
17 replies to this topic
#16 Aridgerunner
Aridgerunner
  • 123 posts
  • Local Club: None
Posted 07 May 2025 - 10:00 AM
I'll do that using a red dye. Probably won't be until Thursday though. I have a big list of "honey do's" to get through today.
I just received a reply from Mini Spares. They say that all of the gears they have in stock are from a batch of Rover new/old stock that they purchased in 2018. They said that they did check some of their stock and could not find any looser gears.
So at this point I either force it on or find a way to make it fit a tad easier.
I'll keep ya posted.
Edited by Aridgerunner, 07 May 2025 - 10:37 AM.
#17 viz139
viz139
  • 676 posts
  • Local Club: Irish Mini Owners Club
Posted 08 May 2025 - 10:13 AM
I take it its not hitting the main bearing retainer. The taller final drives require a different retainer for clearance.
#18 Aridgerunner
Aridgerunner
  • 123 posts
  • Local Club: None
Posted 08 May 2025 - 04:15 PM   Best Answer
Fixed it!
Thanks again!
Bill
