Growing Knocking Noise
suspension
5 replies to this topic
#1 The Portly Knaresbruffian
  • 28 posts
Posted 15 May 2025 - 12:02 PM
Just started hearing a knocking from the front OS wheel (pretty much in time with the rotation) when I turn left (when weight is thrown on this wheel). It isn't affected by brakes or clutch so I'm guessing it's related to driveshaft/wheel bearing/ball joints etc.
Just wondered if anyone has experienced similar before I get my hands dirty.
Late 80's carb model with 10" wheel conversion.
#2 Chris1275gt
Chris1275gt
  • 969 posts
Posted 15 May 2025 - 12:38 PM
CV joint caused those symptoms on mine.
#3 john2502
john2502
  • 139 posts
Posted 15 May 2025 - 03:16 PM
Very quick/easy thing to check is are the wheel nuts all tight.
#4 Spider
  • 15,229 posts
Posted 15 May 2025 - 06:47 PM
Wheel Bearing play and the head of one wheel stud tapping on the brake caliper.
#5 The Portly Knaresbruffian
  • 28 posts
Posted 15 May 2025 - 07:36 PM
Thanks all. I checked the wheel nuts as soon as I noticed and it's not that. Looks like a busy weekend.
#6 The Portly Knaresbruffian
  • 28 posts
Posted 17 May 2025 - 01:39 PM
It was the CV joint. The clip on the larger boot end had leaked grease and the joint was nearly dry. Refilled and clip replaced. Job done.
Also tagged with one or more of these keywords: suspension
