Noisy Mini
21 replies to this topic
#16 Ethel
  • 26,045 posts
Posted 20 May 2025 - 11:51 AM
If you can whiff fumes are you sure you haven't got a bit of an exhaust leak somewhere?
#17 bpirie1000
bpirie1000
  • Area Managers
  • 2,369 posts
  • Local Club: Amoc
Posted 21 May 2025 - 06:14 PM
If you can whiff fuel or gasses mr MOT man will also... that means a fail..
#18 Rubbershorts
Rubbershorts
  • 367 posts
Posted 21 May 2025 - 08:06 PM
Is it acceptable to add an extension onto the tail pipe of the RC40? I've always thought ours should have extended further out the back. I wouldn't mind trying it to see if there is any further noise reduction. Daz.
#19 imack
imack
  • 2,195 posts
Posted 21 May 2025 - 08:10 PM
I extended the tail pipe and front pipe of a twin box rc40 in the 80's to make a saloon exhaust fit an estate.
#20 germini30
germini30
  • 699 posts
Posted 21 May 2025 - 08:59 PM
My new Rc40 has arrived. I'll fit it tomorrow and see where the tail pipe ends. I can always order a trim to extend it
#21 alpder
alpder
  • 444 posts
  • Local Club: MCR
Posted 21 May 2025 - 09:07 PM
The LWB version of the Maniflow RC40 comes with an extension that goes between manifold/downpipe and the front box, plus a tailpipe extension. I imagine the tailpipe is available separately. It's big though and has a rolled end - it's really not subtle.
Alternatively MIJ Exhaust will make an extension from any size s/s pipe with any size clamp-on expansion at one end for under £20 delivered. I've just had them make up an "exhaust joiner" from plain s/s pipe with one expansion (45mm ID) at one end but plain at the other end. Used it as a tailpipe. Arrived 2 days after the order was placed. Fitted onto the end of my exhaust perfectly. They'd make the exact length you want, if asked. I just chopped mine down from the standard size - gave me a chance to eye it up before deciding.
#22 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 21 May 2025 - 09:22 PM
I needed something similar for the PUP. Seem to remember I bought a shiny end bit from halfords as I was passing. That's on a single box rc40
https://www.halfords...3mm-109078.html
Edited by IronmanG, 21 May 2025 - 09:23 PM.
