How Many Amps Drawn By Auxiliary Fan?
Best Answer floormanager , 31 May 2025 - 06:59 AM
Agree. The part you've circled is the thermal switch. If you ground out the wire on 85, then with the ignition on, the fan should work, so taking the wire from 85 through a switch, with the other terminal on the switch grounded, the fan should run.
Go to the full post
Posted 26 May 2025 - 03:44 PM
Posted 26 May 2025 - 06:57 PM
Posted 26 May 2025 - 07:43 PM
More than the wire, or fuse, is rated. Floormanager's info seems on the money 14awg is 2mm2 The fuse will also be what a blade fuse will be marked.
You might want to consider the terminals (1/4" spade?) & whether it illuminates too.
Posted 26 May 2025 - 08:19 PM
The battery is disconnected when not using the car, so not in flames at the moment.
Posted 26 May 2025 - 09:51 PM
Is it not using the original wiring, if there was a thermal switch? Stalled motors don't have much resistance, so a fuse is always a good idea where one is involved.
Putting a relay in place of, or in tandem with, the thermal rad switch would be the easiest way. You could then tap a live for the manual switch, to operate the relay, of pretty much anything downstream of a fuse. The heater fan switch would be easy, with a piggyback spade.
Posted 27 May 2025 - 05:36 AM
Edited by Rubbershorts, 27 May 2025 - 05:46 AM.
Posted 27 May 2025 - 05:39 AM
Edited by Rubbershorts, 27 May 2025 - 05:45 AM.
Posted 27 May 2025 - 05:45 AM
Posted 27 May 2025 - 06:35 PM
Posted 28 May 2025 - 11:45 AM
Posted 28 May 2025 - 12:20 PM
Posted 28 May 2025 - 06:52 PM
Posted 28 May 2025 - 06:58 PM
Wattage divided by 12 (volts) = amps
Or to put another way, on a 13a fuse you can handle up to about 150watt
You could also set it up in series with a voltmeter and run it up for a few seconds reading amps, see what it pulls
Edited by stuart bowes, 28 May 2025 - 07:01 PM.
Posted 28 May 2025 - 07:07 PM
Is it not already switching a relay? I thought there was one on the aux fan circuit, or is that only the injection models?
...The wiring diagram I've got (not sure if it's only SPI, but don't see why it'd be any different) shows the radiator switch switching the coil of the motor relay to earth. A light green/white wire coming from terminal 85 on the fan relay. If that's right, you'd only need a single wire to the dash switch, that the switch earths.
The relay should be on the bulkhead to the left of the wiper motor - a bit of neater place to tap off for the switch.
