How Many Amps Drawn By Auxiliary Fan?
Best Answer floormanager , 31 May 2025 - 06:59 AM
Agree.  The part you've circled is the thermal switch.  If you ground out the wire on 85, then with the ignition on, the fan should work, so taking the wire from 85 through a switch, with the other terminal on the switch grounded, the fan should run.
Go to the full post
21 replies to this topic
#16 Rubbershorts
Rubbershorts
  • 743 posts
Posted 28 May 2025 - 08:26 PM
Is it not already switching a relay? I thought there was one on the aux fan circuit, or is that only the injection models?
...The wiring diagram I've got (not sure if it's only SPI, but don't see why it'd be any different) shows the radiator switch switching the coil of the motor relay to earth. A light green/white wire coming from terminal 85 on the fan relay. If that's right, you'd only need a single wire to the dash switch, that the switch earths.
The relay should be on the bulkhead to the left of the wiper motor - a bit of neater place to tap off for the switch.
Okay Ethel, these two on bulkhead, the right hand side one has a light green/white wire that indeed goes to 85 on that relay. Do I take a single wire from that green/white wire to a switch that is fixed in an earthed position, and when the switch is activated it earths pin 85? And this should start the fan?
#17 Rubbershorts
Rubbershorts
  • 743 posts
Posted 30 May 2025 - 09:50 PM
You'd normally wire the fan through a relay, so the amperage going through the switch is small, something like this:-
Hi Floor manager, thanks for the diagram. Is the circled bit the thermal switch? If it is I think with this, and Ethel identifying the ground wire as the white/green that goes to 85 on the relay (it's black on your diagram), I think I've got it. Can I break into the ground (green and white) and take a single wire into the cab to the earthed switch? Cheers, Daz.
Edited by Rubbershorts, 30 May 2025 - 09:52 PM.
#18 Ethel
  • 26,822 posts
Posted 30 May 2025 - 10:55 PM
I reckon so, ignition will need to be on too of course. Looks like you can push a wire in to the relay holder & earth nearby to confirm.
#19 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 31 May 2025 - 06:59 AM   Best Answer
#20 Rubbershorts
Rubbershorts
  • 743 posts
Posted 31 May 2025 - 07:52 AM
Excellent, cheers guys, I'll give that a go later on.
#21 brivinci
brivinci
  • 1,225 posts
Posted 03 June 2025 - 06:51 PM
Wow, read through this and wish I had knows this a month of so ago. I was on a road trip and noticed the car getting warm in traffic. My aux fan never turned out. Turns out the fairly new screw-in sensor from spares had failed. Having an override switch would be great. I installed an electric fan kit on a classic Thunderbird and it came with the override switch, which seems like a good idea. I am going to test this and see about officially wiring this up.
Great info!
#22 Rubbershorts
Rubbershorts
  • 743 posts
Posted 04 June 2025 - 05:05 PM
Great info!
Yeah, mines up and running correctly now. Just the one wire from pin 85, as the guys advised, and no live wires running to the switch anymore.
Edited by Rubbershorts, 05 June 2025 - 06:02 PM.
