Brake Line Flares, Types, Sizes
Best Answer Spider , 06 June 2025 - 06:06 PM
If you are unsure if a Port is 3/8" UNF or M10 x 1.0, as they are very close and a 3/8" UNF Tube Nut will screw in to an M10 x 1.0 Port, but is potentially dangerous, one way to work out what you have is if you have an old tube nut that you know came from it, try screwing it in to a wheel nut. If it goes in, it's most likely 3/8" UNF and if it doesn't, then M10 x 1.0. Another similar way is to obtain an M10 x 1.0 screw and use that for testing.
The Single Circuit Master Cylinders are 3/8" UNF.
The CMC 159 and GMC160 Tandem Masters are 3/8" UNF on both ports.
The GMC 167 (sometimes called a Green Tag) Master Cylinder is M10 x 1.0 on both ports. There is an earlier version of these (black tag) that were 3/8" UNF.
The GMC 227 (yellow tag) is M10 x 1.0 and M12.x 1.0
The GMC90376 I need to check and confirm.
The FAM7821 and the FAM4670 are M10 x 1.0
All other Brake Valves are 3/8" UNF
All Brass Tee's and other Unions are 3/8" UNF.
All Brake Hoses are 3/8" UNF
Most Joiners are 3/8" UNF, however, there were some M10 x 1.0 used too. BE AWARE most of these take a Invert Flare (refer to the link below on Flare Types for a correct description of these), though some use Doubles. You will need to confirm the Thread and Flare type needed here.
All Wheel Cylinders are 3/8" UNF.
For completeness, the Factory twin pot Brake Calipers are 3/8" UNF, though these have the hoses screwed directly in to them, with a copper sealing washer.
Flare types;-
https://www.theminif...ngs-and-flairs/
Go to the full post
17 replies to this topic
#16 mbolt998
mbolt998
  • 390 posts
Posted 07 June 2025 - 10:21 AM
So now I'm really confused again :) It looks from that post about the flare types that if I do the first operation with my tool, that's actually a "double flare". If it then turn the tool around and do the second operation, I have an "inverted" flare. Is this right?
Correct.
Those are the Terms used by the SAE and the only ones I use.
I have seen in particular the 'double flare' term interchanged with an invert flare may times - as per Bobbin's post above (and note that is not from the standards) - and as you can see, from the SAE and BMC Standards, they are very different things.
Most tooling works as you have said, first operation is to make a Double Flare then if it's needed, from the Double Flare, form an Invert Flare. I have a few tools for making them, they all work this way.
Thank you for clearing this up! I will try to remember. The confusion arises I think because you do two operations with the tool to get the inverted flare, and that feels like "double" of something, and like if you only did the first bit you would have a "single" flare.
I used inverted flares everywhere on my car, including both sides of an inline junction, which probably should have been double into inverted. But it's not leaking.
#17 stuart bowes
stuart bowes
  • 2,194 posts
Posted 07 June 2025 - 11:56 AM
so just to round out the post and make sure I do actually understand (always worth a double check and others might find it useful)
if the fitting you're connecting to has a convex ('outy') mating surface then you want one of these
and if the fitting you're connecting to has a concave ('inny') mating surface then you want one of these
and once you've done them up nice and tight they not only give a good seal, but also the shape of the fixings holds that flare in place and prevents it being deformed again, i.e. will not break free or pop out
pretty obvious really once you know, my mistake was not paying attention closely enough to realise there were a mixture of the two types on the car that's all
and then the thread sizes are as per Spiders very useful post above marked in green (again, recognise there are are different types mixed up around the car)
im not a huge fan of the way the tool grips the pipe and marks it, but it is superficial as far as I can tell, the fixing covers it up anyway so im not losing sleep over it
I've opted for long male fittings and short female fittings, that way as it tightens you can see some 'spare' thread left and you know you've hit the bottom of the connection and pulled it in tight, as opposed to running out of thread and not being sure if that's why it wont turn any further
Edited by stuart bowes, 07 June 2025 - 12:09 PM.
#18 weef
weef
  • 501 posts
Posted 07 June 2025 - 11:58 AM
Essentially what is happening when you use the "inverted flare"  is that when tightening you are using the tube nut to deform the flare to make the seal, basicly replicating the second flaring tool  operation.
 This practice make well work on the soft copper tubing but may not be so successful if the tubing is steel or the more common cupro nickel tubing used in brake line renewal.
Now you understand the flaring principal, please flare the correct profile for the job in hand.
