Spi Struggling To Start And Cold/hot Idling Issues
39 replies to this topic
#31 BritOP94
BritOP94
  • 21 posts
Posted 24 June 2025 - 06:30 AM
Attached File  2025-06-24_07.37 engine off throttle test.txt   44.78K   3 downloads
Throttle pot test from this morning, one long at full throttle, 3 short ones then another long full one.
You can see the IAC setting itself right at 35 too.
Then cold start, erratic idle during which I tried to keep it from stalling with some throttle
Tested the MAP lines too, 99-100kPa when I unplug the vac line...
Got the manifold out this morning, will check everything from the loom while it's out, replaced the coolant sensor while I'm there.
Is there anything else that can be physically checked/tested? Manifold heater maybe?
Edited by BritOP94, 24 June 2025 - 06:31 AM.
#32 BritOP94
BritOP94
  • 21 posts
Posted 24 June 2025 - 06:32 AM
did you have a reset of the ecu already and possibly you gave the system not enough time to stabilize itself
2500 viewers up to now and no other ideas???????
Once I get the manifold back on the engine I'll try again to do the whole procedure, resetting the ECU, the IACV and try to do so as slowly as possible...
#33 hungdynasty
hungdynasty
  • 179 posts
Posted 24 June 2025 - 09:18 AM
Got back, plugged the computer: water temp around 90°C, got into closed loop this time, throttle pot 0.56v at idle, but the IACV is still switching 0 and and usually around 49.
I followed Genpop's procedure, then checked the lost motion gap again, but the main problem is still there : it feels like the IACV is just kind of "giving up". when fully warmed up, it will only sit at a higher number than it should, then suddenly drop down to 0 which makes the engine surge and stall if not helped with the throttle. A blip of the throttle brings up the rpms, the IACV follows too and climbs, but when it tries to get back to a stable idle, the IACV drops back down to zero etc...
Hi, your situation is almost exactly my case back in few months ago,
high idling (11xx-12xxrpm) with fully warm engine, map reading normal at around 30 kpa
stepper motor down to 0 position
throttle physically at dead close position, if looking closer, the stepper motor push rod didn't even touch the throttle.
What I though is the stepper motor tried to reduce the rpm by reducing steps, all the way to 0. "Normal" map reading was misleading because throttle was dead close with high rpm, when I read my log file I saw something interesting, (please see attachment), there was a short moment the rpm went back to normal(around 900) rpm and the map reading went up to 4x, which is very likely there was a leak in the system. Finally I found that the two gaskets between throttle body-spacer-intake were damaged, I replace the two gaskets and everything back to normal.
Attached File  log 250122 reference.JPG   85.63K   3 downloads
#34 68+86auto
68+86auto
  • 1,477 posts
Posted 24 June 2025 - 11:32 AM
To start with, I haven't touched an SPI mini before so I can't go into detail specifically about SPI minis. From what I understand, it is unlikely that the ECU cares much about anything when trying to start. Basically just the temperature to enrich the mixture and the crank angle sensor for timing. Maybe I'm totally wrong though.
So why won't it start easily or run properly?
Because you have had it started and it still had issues, I'm going to skip over the battery voltage and starter. So it's a rebuilt engine which I guess has never been run properly before. That means that we could easily be dealing with a mechanical issue such as poorly sealing or poorly adjusted valves. I've seen that before on rebuilt engines where the machine shop assembled the heads. We need to know that the engine has sufficient vacuum to draw the fuel into the combustion chamber. Put a vacuum gauge on a manifold vacuum source and crank. This reading should be somewhere above 6 inHg, my current mini with an old original engine pulls 10.8 inHg at 300 cranking rpm.
Once the engine is running, this reading should be above 16 inHg.
Vacuum diagnostics is a very old method but is very useful.
Once we are sure that the engine is mechanically ok, we can move to the ignition and fuel system. These are just some things I'm thinking of:
  • Check that it has the correct coil (0.9ohm?).
  • Check that the coil gets above 12v.
  • Scope the crank angle sensor - for all we know the crank trigger was damaged during the rebuild.
  • Check the voltage at the injector
Just like a carbureted engine, starting fluid can be used to see if it's a fuel delivery issue.
#35 genpop
genpop
  • 536 posts
Posted 24 June 2025 - 03:36 PM
@ hungdynasty,
I think you are right, it would be a simple and logical solution, i often think too complicated and forget the simple things.
In this case we would say: Because of all the trees I didn`t see the forest!
I hope we will get good news.
Edited by genpop, 24 June 2025 - 03:37 PM.
#36 BritOP94
BritOP94
  • 21 posts
Posted 06 July 2025 - 04:06 PM
Ok, had a bit of a crazy week at the shop so not much time to work on the SPI, but the weekend allowed me to be more productive...
Fitted my new starter motor and that solved all starting issues. Guess the old one was shorting somehow, despite not causing that much of a draw on startup. Anyway, at least that's sorted now.
Thank you to everybody who's taking some time to participate and share their ideas, again, it is much appreciated (and needed!).
@hungdynasty
That's very much like what I'm experiencing indeed, and the more I think about it the more I want to say there's an air leak somewhere.
I double checked my logs though, but I can't find any high MAP reading that could point to that. When left idling (always erratically, still sound as unstable as before.) at about 1000-1200rpm I'm always getting readings between 26-29 kPa.
But still, I'm trying to make sure there's no leak I could have missed. So to recap, all rubber hoses have been replaced, all vac lines too/replaced by silicone hoses, the intake spacer gaskets are new, the manifold gasket too... I've tried spraying brake cleaner on said hoses/gaskets/pretty much everywhere in the intake area but there's no noticeable rpm difference while I'm doing so.
Is there something else that could cause an air leak somewhere? I feel like I'm missing something obvious here.
@68+86auto
I've been working on carburetted Minis for a good while now, and I can assure you that SPi's and MPi's are indeed very very different beasts haha
I've reassembled the engine and the head myself after I got them back from machining, compression on all four cylinders is good, valve seats done and clearance are triple checked.
The coil is the correct ballasted type and I'm getting around 3.30-3.50ms charging time at the ECU (which I think is fine? Can anybody confirm this please?). It is getting over 13 volts when running too.
Crank sensor is good, those just won't run if there's anything wrong with it.
Haven't had a chance to check the injector signal nor how much voltage it is getting, will check that asap.
#37 BritOP94
BritOP94
  • 21 posts
Posted 06 July 2025 - 04:10 PM
On other news, we have another SPi in the shop right now so I'm using this as an opportunity to check and compare stuff as this one is running great.
#38 genpop
genpop
  • 536 posts
Posted 06 July 2025 - 04:29 PM
Hi Brit*,
when i check the log again, i see the fluctuation on the map-curve too.Like you said 26 to 29 KPa and that is the same fault what hungdynasty had.
On idle, it should be steady. You asked for other possible  leaks . What about the brake booster? The oil filler cap and the purge canister valve?
#39 hungdynasty
hungdynasty
  • 179 posts
Posted 06 July 2025 - 04:50 PM
This is from mensfcr
This is the time for the ignition coil to charge up to its specified current, as measured by the MEMS ECU. With a battery voltage of about 14V, this value should be about 2-3mS. A high value for coil charge time may indicate a problem with the ignition coil primary circuit.
#40 68+86auto
68+86auto
  • 1,477 posts
Posted 06 July 2025 - 10:39 PM
@68+86auto
It will run with a bad or dirty crank angle sensor but cause issues. For one example, have a read of this: https://www.theminif...l=+misfire +spi
SPIs are different but the only difference is that there is no mechanical advance and no carburettor. The faults of every other component can still occur.
