4 Fuse Box
5 replies to this topic
#1 Murrayup
Murrayup
    Just On Tickover
  • 5 posts
Posted 20 June 2025 - 01:07 PM
I’m posting a photo of my current old fuse box.
Apart from most of the wires covered in oil does
This look to have the wires in the right place.
The clean white wire is new and goes to the coil.
The horn works but have not yet tested lights w/w
Heater. 998 1973 mini clubman. Engine does run.
Thought they were supposed to have 2xfuse box.
Regards to all Ian.
#2 nicklouse
  • 18,677 posts
Posted 20 June 2025 - 01:41 PM
As all the terminals are not original it might have been an upgrade from a PO.
#3 Ethel
  • 26,040 posts
Posted 20 June 2025 - 02:44 PM
White is ignition live
Brown is permanent live
Green/white is accessory (1st ignition key position)
Red is output from the light switch for side, tail, dash...
https://www.theminif...s-covered-data/
#4 viz139
viz139
  • 680 posts
  • Local Club: Irish Mini Owners Club
Posted 24 June 2025 - 07:39 PM
The original 2 fuses would be .
White going to dark green like the fuse on the right
Brown going to Purple  ,Brown may be on top left but I don't see purple.
If you pull back the  corrugated  plastic cable cover you will see the original wiring taped into the loom and anything else is added.
Looks like a lot of diy going on there
#5 Murrayup
Murrayup
    Just On Tickover
  • 5 posts
Posted Yesterday, 03:10 PM
Yip there has been a lot of fiddling with this clubman. Thanks for the info. Bought a new 4 fuse box so it’s back to the Hainess manual .regards.
#6 stuart bowes
stuart bowes
  • 2,219 posts
Posted Yesterday, 03:59 PM
the wiring diagrams on here are much better I find especially if you can print A1 or A0
just clearer and easier to trace
https://www.theminif...agrams-redrawn/
if you let us know details like model / age someone will no doubt help you find the right PDF
Edited by stuart bowes, Yesterday, 04:03 PM.
