Opinions On Wheel Arch Trims
Best Answer mab01uk , 22 June 2025 - 07:14 PM
The plastic wheel arch extensions were added by BL/Rover to cover the tyre tread when larger 12" wheels replaced the earlier 10" wheels fitted to Minis which did not need arch extensions.
The UK MOT requires tread to be covered when viewed from above.....although the earlier Mini 1275GT fitted with 12" wheels had no plastic arches it was borderline legal with some tyres.
Assuming that having no arches will be ok and road legal in France, you will have the plastic arch rivet fixing holes to fill plus any rust areas, which may mean you have to have your car paintwork repaired.
Go to the full post
7 replies to this topic
#1 mullet
mullet
  • 170 posts
Posted 22 June 2025 - 04:05 PM
Hi all.  My mini has these kinds of trims, but they were all cracked so I just drilled out the rivets and removed them.  My intention was to replace with a kit:
https://www.thelittl...aultcombination
But now I realise they were hiding quite a bit of rust (I will clean up and hammerite the out of sight areas).
So what is the opinions of others?  Are there any pros and cons to not putting new ones on?  I also thought about this product instead as any new rust would be easier to spot without the trouble of rivets:
https://www.thelittl...-a-l-unite.html
Thanks for your ideas!
Edited by mullet, 22 June 2025 - 04:05 PM.
#2 mab01uk
mab01uk
  • 13,033 posts
Posted 22 June 2025 - 07:14 PM   Best Answer
Edited by mab01uk, 22 June 2025 - 07:18 PM.
#3 mullet
mullet
  • 170 posts
Posted 23 June 2025 - 08:32 AM
Thank you.  I didn't know regarding the history of these plastic trims.  I'd always thought it was one of these 80s ideas!  I'll be cleaning it up and hammeriting the rusty areas and be replacing then.  Thanks again.
#4 lippo
lippo
  • 163 posts
Posted 23 June 2025 - 08:46 PM
 Hi Mab, my Clubman Estate has no wheel arches and Cooper S brakes, so the front wheels protrude about an inch. It was put through an MOT last year and received an advisory relating to the wheels. I was surprised that it didn't fail but some recent google searching has revealed that a car cannot fail the MOT on protruding wheels, it is an advisory only.
 I have now fitted Minifins to the rear, so all 4 are sticking out slightly!
https://www.reddit.c...ing_beyond_the/
#5 Ethel
  • 26,755 posts
Posted 24 June 2025 - 10:48 AM
Those arch extensions first appeared on the 1979 1100 Special, which had 10 inch alloy wheels. If my memory isn't playing tricks they were available as a kit, including wheel spacers, from Unipart.
The 12 inch cars also had discs & "S" type rear drums.
#6 imack
imack
  • 2,377 posts
Posted 24 June 2025 - 05:32 PM
I bought a Mini Special wheel arch extension kit from Austin Rover. I don't remember it coming with wheel spacers, but it did have large washer/spacers to fit between the front bumpstops and the subframe and the mushroom shaped metal bumpstop extension to fit in the rear subframe inside the rubber cones.
#7 mab01uk
mab01uk
  • 13,033 posts
Posted 24 June 2025 - 07:13 PM
Useful to know, thanks for the info. Main problem I used to find with a 12" wheel 1275GT without arches was the the dirt thrown up from the tyres on the sides of my nice clean car when driving on a wet day!  :lol:
Edited by mab01uk, 24 June 2025 - 07:14 PM.
#8 Ethel
  • 26,755 posts
Posted 24 June 2025 - 09:18 PM
I could easily be confused, perhaps it's that they didn't have spacers, but you could well need them. This would be around 1980, I guess it could've changed by the time they were on 12s.
