Spi Bad Idle And 'tapping' Engine Sound
engine
11 replies to this topic
#1 Simmi Westo
Simmi Westo
    Starting My Mini Up
  • 3 posts
Posted 15 July 2025 - 08:11 AM
HI all,
1995 - SPI - 1.3
Typically, we were due to attend a local classic car show this Sunday and the mini decided she didn't want to go!
Problem: At first, it sounded like it was misfiring, and then a 'tapping' sound started. Now, it won't idle properly and cuts out if not revved.
I've checked the vacuum pipes and all seem to be ok - replaced on a few weeks ago as it was cracked.
A few people have suggested it could be the head gasket, but could this cause both the bad idle, cutting out and the tapping sound??
Note, the tapping sound is coming from the 'top' of the engine.
video link here to see the issue: https://youtube.com/...U?feature=share
I've bought a compression tester and will check the compression today and report back if there are any issues there.
Any ideas?
Edited by Simmi Westo, 15 July 2025 - 02:21 PM.
#2 Ethel
  • 26,173 posts
Posted 15 July 2025 - 10:28 AM
Too many to be useful.
A compression test will be a useful starting point. Take all the spark plugs out. Let the battery & starter recover between cranking.
#3 Simmi Westo
Simmi Westo
    Starting My Mini Up
  • 3 posts
Posted 15 July 2025 - 02:21 PM
Assume you meant video:
Here is link to see the issue: https://youtube.com/...U?feature=share
Any advice is appreciated.
#4 Jarvis_SPI
Jarvis_SPI
  • 55 posts
Posted 15 July 2025 - 09:04 PM
I would take the rocker cover off and check the valve clearances first.
#5 Designer
Designer
  • 650 posts
  • Local Club: LSMOC
Posted 16 July 2025 - 06:00 AM
Hi,
Another thing to check is whether or not the top of a rocker adjuster screw is hitting the rocker cover.
Examine the inside of the cover carefully for any minor dents relative to the adjuster screws.
Paddy
#6 Simmi Westo
Simmi Westo
    Starting My Mini Up
  • 3 posts
Posted 16 July 2025 - 07:19 AM
Hi,
Paddy
Thank you will check this - would this also cause the bad idle too?
#7 madazv8
madazv8
  • 149 posts
Posted 16 July 2025 - 11:04 AM
When I got my car it ran like a bag of spanners and the engine clattered at very low RPM, it smoothed out once I got the revs up. I chased a bad/low idle for some time until it was eventually found to be a bad water temp sensor,  causing the ECU to over fuel.   Might not be the same as yours,  just sharing my experience, you will be able to tell if you are rich by a sooty exhaust,  or black plugs.  Good luck.
#8 Designer
Designer
  • 650 posts
  • Local Club: LSMOC
Posted 17 July 2025 - 05:01 AM
Hi,
#Thank you will check this - would this also cause the bad idle too?
Sorry I was referring to the possible cause of the knocking noise.
With regards to the bad idle others on here will be more knowledgeable to answer that.
Paddy
Edited by Designer, 17 July 2025 - 05:01 AM.
#9 Ethel
  • 26,173 posts
Posted 17 July 2025 - 09:37 AM
The idle air control valve would be the obvious candidate on an injection Mini. It might also be the cause of the noise as an uneven idle could constantly load & unload the timing gear. It might just be poor electrical contact in its connector.
#10 NLinPEN
NLinPEN
  • 112 posts
Posted 17 July 2025 - 01:07 PM
My understanding is that only the MPi has an idle air control valve. The OP has an SPi car.
#11 Ethel
  • 26,173 posts
Posted 17 July 2025 - 03:42 PM
I'm no injection wizard, perhaps I should have said stepper motor which does the same job.
... found this excellent vid as a result though
https://youtu.be/jGNwTtdM6rw
#12 FlyingScot
FlyingScot
  • 2,672 posts
Posted 13 August 2025 - 06:44 PM
On fuel injection cars most people immediately think of sensors, injection unit or ECUs.
You have to start with the basic mechanical tests as some have listed above namely, loose parts, contacting parts (fan blades on the radiator for example) and confirmed mechanical settings (tappets, compression and oil pressure for a start). Plus obvious signs, smoke leaks etc
All this must be validated before any thought to the SPI parts (on this particular car) and even then it is usually simple stuff like corroded 20 year plus wiring , vacuum pipes and the like - the actual system components are robust.
FS
