Radius Arm Bracket Bolt - Just Spinning!
suspension
3 replies to this topic
#1 minicooper1.3i
minicooper1.3i
  • 874 posts
  • Local Club: na
Posted Today, 05:54 PM
Evening all
A couple of years ago, I went to remove the offside radius arm in order to service it, and one of the bolts that's partially hidden behind the arm just started spinning. Presumably the captive nuts inside the subframe has broken free.
So the question is, is there a way of getting that arm off without removing the rear subframe? I've heard too many horror stories of subframe bolts snapping off inside the sills to risk it at the moment. I've got a spare radius arm bracket should I need it but no spare bolts, although I'm sure I could source some. I'd also need a way of refitting the arm of course, so not sure if the knackered captive nut could be replaced with a helicoil or not. The sheet metal of the subframe might be too thin. Dunno, never used them before.
Got first MOT in 4 years booked in for end of next week and although I've packed the arms with grease I'm not confident it'll pass. Just want to get it back on the road for a couple of months to enjoy the last of the summer before (with any luck) and can start planning the full strip down refurb of the entire car 🤞
Appreciate any suggestions with the above. 🙂
#2 whistler
whistler
  • 1,833 posts
Posted Today, 06:00 PM
I would suggest you have the MOT first. You could drill the head off, just to remove the arm but you're opening up a whole can of worms. MOT it first, if it's likely to pass.
#3 stuart bowes
stuart bowes
  • 2,267 posts
Posted Today, 06:03 PM
nowhere near thick enough for a helicoil, you need a proper welded on nut on the back side
only way to access that is lower subframe to get at the back side
theoretically someone sufficiently skilled could cut the subframe and do the repair then weld it back in, but that's probably more work than just dropping the subframe (and still not really ideal)
I'd just take a gamble at the subframe trunnion bolts being ok, and if not then cut a section out of the sill to do that repair instead, at least that isn't an important structural component
Edited by stuart bowes, Today, 09:21 PM.
#4 alpder
alpder
  • 450 posts
  • Local Club: MCR
Posted Today, 06:22 PM
Try for an MOT, and leave the work until autumn. If you drop the subframe now, the summer could be gone before you've fixed all the horrors that you find on and behind it.
If you haven't already, ask around for a local garage that understands old cars. Explain the subframe is scheduled to be out this autumn for a service... if it's marginal then that might swing you an advisory.
Alternatively, if radius arm just has to be done now and you don't mind quick and (very) dirty: drill out the bolt, service the arm, refit the bracket with two bolts and a plug-weld in the remaining hole. When you come to drop the subframe and fix it properly later, you'll need to fettle a new hole and its welded nut on the subframe, and obviously a new bracket too once you've ground the old one off.
Also tagged with one or more of these keywords: suspension
