Sportspack Rear View Mirror
3 replies to this topic
#1 Rosco320
Rosco320
    Starting My Mini Up
  • 4 posts
Posted 16 August 2025 - 10:22 AM
How do you dismantle the mirror from bracket? Im assuming this wee cover pops off? Anyway of replacing glass as can see glue or delamination around edges and that will do one's nut in 😂
#2 bpirie1000
bpirie1000
  • 2,554 posts
  • Local Club: Amoc
Posted 16 August 2025 - 10:44 AM
I think......
Think mine slide upwards. Leaving a small bracket on yhe window.
This was decided best option to elliminate thr shakr rattle.and roll of the early screwed to roof panel type...
Unfortunatly sticky mess it is ...
#3 Steve220
Steve220
  • 5,137 posts
  • Local Club: BMC
Posted 16 August 2025 - 07:56 PM
I've tried to dismantle one in the past, it's glued together. The glass delaminates over the years if its left outside or been in a hot area.
To remove it, you need to push it up. I lightly use a small toffee hammer to get it started.
#4 MikeRotherham
MikeRotherham
  • 1,028 posts
Posted 17 August 2025 - 07:57 AM
If you can get hold of a good second hand one. A number of cars used the same mirror.
Can you can pop the mirror off the swivelling mount and then just pop the replacement on?
I did it on an older style one but not sure about the later one.
Edited by MikeRotherham, 17 August 2025 - 07:59 AM.
