Battery Remote Isolator Switch
6 replies to this topic
#1 Mixagon
Mixagon
  • 39 posts
Posted 28 August 2025 - 10:45 AM
Hi, is anyone using a remote battery isolator switch similar to this one, just wondering if there any good?
https://ebay.us/m/pC0hK8
#2 bangermadness08
bangermadness08
  • 283 posts
Posted 29 August 2025 - 02:12 PM
154221790617 Hope the link works but i use this. cheap and works well.
#3 Mixagon
Mixagon
  • 39 posts
Posted 29 August 2025 - 04:51 PM
I've seen those but didn't want to keep opening the boot to switch it, I thought the remote ones would be very popular but no replies so maybe not very good after all.
#4 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 29 August 2025 - 05:18 PM
Cheaper here:
https://www.ebay.co....8.c101506.m1851
"2.Automatic Cut Off
If the voltage is lower than 11.8V, the remote kill switch will automatically cut off the power supply after 120s to save electricity, if the voltage is higher than 13.2V, the remote control will be disabled to prevent accidental action to shut off the power while driving, and the power supply can only be controlled by the button on the switch."
I, personally, wouldn't risk cheap electronics initiating a shut off, potentially caused by a charging issue, leaving me without lights on a coutry road or, worse, a motorway.
#5 unburntfuelinthemorning
  • 2,003 posts
Posted 29 August 2025 - 08:53 PM
I prefer the isolator switches like this which can be switched off with the engine running without damaging the alternator.  The one I have is very reliable and adds a little extra security.
Edited by unburntfuelinthemorning, 29 August 2025 - 08:54 PM.
#6 nicklouse
  • 19,067 posts
Posted 29 August 2025 - 10:08 PM
Only one of the isolators will sop the engine if bumped or jump started.
a visible deterrent works way better than an invisible one.
#7 Gaz66
Gaz66
  • 1,202 posts
Posted 30 August 2025 - 10:47 AM
Likewise 👍
