Hello,
Hoping someone here can point me in the right direction.
1978 Morris Mini 1000. Newly rebuilt engine (A series, 998)
HS4 carb, looks to originally have been off a 1100cc or something, but history not totally known. Its tag is AUD608. Changed the needle for a 998 one already.
Cleaned it up, put in new spindle bushings, spingle, red jet, needle etc, and all was pretty good. However the butterfly I didnt replace, and there was quite an obvious gap around the outside when fully closed.
Also, the butterfly was the WZX1324 type it seems, with the hole in it. Designed for Waxstat jets it seems, and is there for Antistall - based on Minispares description.
I dont have a Waxstat jet though, old one was the red type, and replaced it with a new red type.
Drove pretty good, was running rich until I replaced the jet, even with it turned all the way lean. Better now. However still not perfect.
Ended up buying a new WZX1323 kit, which is the solid butterfly, without the hole.
Installed it this evening, and now having a few issues which I am not sure about.
Adjusted the idle, as without the hole in there now, the butterfuly has to be opened for it to idle - that is all fine. Started up OK after that was opened a bit, but hunts a bit (not much 100-200 rpm maybe).
Let it warm up, and the hunting somewhat settled. However if you blip the throttle, it falls on its face and almost stalls, and then recovers back to an idle again.
The carb is also emitting a high pitch squeel, which it was not doing before changing the butterfly. It does it across the whole rev range, not just at idle.
Any ideas what is happening here?
Falling on its face after throttle blip, and high pitch squeel.
I assume, for whatever reason, this carb wants a butterfly with a hole in it, and maybe that is what the whole 'antistall' thing is about...
The WZX1324 wasnt in stock here in NZ, so I could just take the butterfly out and drill a hole in it - that is no big deal. But wanting to know what is going on before I do that.
I have no idea what this squeel is about.
Here is a video showing the squeel - ingore what the camera is pointing at, was just getting the microphone closer, but its so obvious that wasnt really needed.
Here is a video of a small throttle blip, and it falling on its face and recovering.
Any ideas?
Appreciate the help
