I'm just rebuilding the front end of the car and finalizing the bracketry on the new inner wings.
I've got a question on the bottom captive nut plate for the shock absorber bracket. On the original car this was welded in place - would it have left the factory like this?
I'm unsure whether to weld this in place - if so, how do I get the correct alignment of the shock bracket - even with the top 2 bolts in place, there is a reasonable (+/-5°) play - I'm assuming the placement needs to be more accurate than that?
2nd question - my original brackets (or what remains of them) are body coloured - Are these brackets normally fitted to the car, before spraying - or are they like any other bolt on element?
