Front End Fitting Process, Tips And Tricks
Best Answer Homersimpson , 03 October 2025 - 09:24 PM
I've done loads of these over the years, both genuine panels and non genuine.
The way I did it was:
1. Repair the doors and a posts
2. Fit the a panels, set the door gaps and weld the a panel top and bottom so its fixed.
3. Bolt the front panel to the subframe
4. Fit the bonnet and get the gap as good as you can at the back.
5. Position the wing and tack the rear corner by the bonnet and front corner by the bonnet to the front panel to set the gap by the bonnet. Repeat for the other side.
6. Pull the wing to the a panel with mole grips with a wide head.
7. Recheck the bonnet gap.
8. Weld the wing to the inner wing along the top.
9. Weld the apanel to the wing.
10. Weld the front panel ears to the inner wing.
11. Clamp the front panel to the wing and weld, working your way from inside (nearest the inner wing) to out tends to help.
12. Dont forget the little angled strengthening pieces welded to the wing lip where it joins the apanel which add quite a bit of strength to the joint.
If things aren't going right then stop and take a step back, sometimes you get a bad panel, sometime moving something slightly makes a big difference to the fit elsewhere..
It should be possible to get a reasonable fit even with patten panels without major reworking, if you have to cut panels up and extend or shorten them chances are that either the panel is wrong made or your trying to achieve a far better fit than the cars had when new.
The last point above is important as these cars had poor gaps from new and try to get them perfect is a time consuming and generally unnecessary endeavor, to top is that the gaps are more critical on light coloured cars than dark coloured ones.  Dark colours hide panel gaps but show dents more!
Go to the full post
9 replies to this topic
#1 CBJ805T
CBJ805T
  • 459 posts
Posted 23 September 2025 - 11:56 AM
Hi,
next on the list is the front end - Front wings, front Panel and A-Panels.
My current plan was to dry fit the front wings and Front panel along with the bonnet and get all the gaps correct, then fit the A panels
Is this the way you'd go?
Do I need to fit the front subframe? or can I just align and clamp the panels in free air
for my first trial fit, the actual fit was terrible, so I've got some fettling to do. I was planning to ignore the A-panels and doors etc until this front end was all sorted, but do I need to look at all of these panels in one go, before welding anything in place?
any tips or tricks appreciated
Chris
#2 Gaz66
Gaz66
  • 1,162 posts
Posted 23 September 2025 - 12:45 PM
Fit front subframe and bolt front panel to it using all new mounts (if rubber mounted)
This will give you a solid datum at the front and back and then fill the void with panels 👍
#3 stuart bowes
stuart bowes
  • 2,607 posts
Posted 23 September 2025 - 02:03 PM
might be an idea to start with the A-panel to door gap
bolt the doors back on and adjust them best you can for good gaps, then fit the new A panels with a good gap along that edge of the door
then the front panel on (see above) and fit the wings in between
#4 Tupers
Tupers
  • 4,176 posts
Posted 23 September 2025 - 08:10 PM
Get the doors on and gapped to the quarters and steps first then to A panels.
Once they’re in place permanently you should fit the front subframe and start aligning the wings, bonnet and front panel.
#5 CBJ805T
CBJ805T
  • 459 posts
Posted 24 September 2025 - 02:22 PM
Thanks all - do doors need reskinning first  - if all of the above is ok to do on the original skins can I leave the reskinning until later?
Edited by CBJ805T, 24 September 2025 - 02:43 PM.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 24 September 2025 - 07:30 PM
You can reskin the doors later and adjust as required. If you want ÂŁ1 coin gaps then some 3.2mm TIG steel filler rods will do the job nicely
#7 Ethel
  • 26,755 posts
Posted 25 September 2025 - 11:03 AM
Working from the back to the front will carry dimensional errors off the front in to thin air. Even so, fit up everything before attaching it permanently. It's the curves where errors creep in. Under flex them & the fit will be too long & lacking in height, over flex.....
Fit the bonnet & use it as a reference for the back of the wing to work on the wing to screen scuttle fit. Have a good straight edge to align the A panel external seam up to the roof. Once you've got the rear of the wing clamped up nicely, you'll have a good target for the A panel between it & the door.
It would help to take the weight of the door off the hinge panel to  stop it flexing. Find some packing for the bottom edge, or hang / clamp the top off the gutter - or you could fashion a bit of wood to stand in for the door's front edge.
#8 CBJ805T
CBJ805T
  • 459 posts
Posted 02 October 2025 - 01:10 PM
Hi all, Managed to spend some time in the garage yesterday, fitting the passenger door and working forwards.
The fit is still horrible - but I'm going to fit the front subframe as well and look at it all again before pestering you on it.
However....bit of a side bar - the door fit was also not great.
I had to fit 3 spacers to the bottom hinge to prevent the door from catching at the opposite side - would you recommend fitting the door catch / stay etc when trial fitting?
I also found that the bottom of the door turned in significantly at the bottom - Is this normal? If not, what do people do to address this?
https://www.amazon.c...VNNDS0DPU4ZeYOB
the doors skins will be replaced, but this is the fit all round
Bottom of A-panel - https://www.amazon.c...zr6hqSXoRlETkOL
Top of A-Panel - https://www.amazon.c...zr6hqSXoRlETkOL
opposite end - https://www.amazon.c...ZVBRMtT2zPGjMfv
#9 Ethel
  • 26,755 posts
Posted 03 October 2025 - 07:55 AM
Fit the door seals, if they're not fitted. It's easy to squeeze in the A posts too much if you have a fits where it touches approach to welding.
#10 Homersimpson
Homersimpson
  • 851 posts
Posted 03 October 2025 - 09:24 PM   Best Answer
