Hi Guys
I have had to change a wheel bearing today.
The problem is..... I cannot get the C.V joint out of the hub.
It appears the bearings have welded themselves to the joint.
My main question is.... If I hit the end of the joint with a large hammer and it does come out am I going to wreck the hub as well?
Thanks in advance
David
Front wheel bearing problem
nomininolife
, Nov 24 2006 10:56 PM
7 replies to this topic
Posted 24 November 2006 - 10:56 PM
Posted 24 November 2006 - 11:00 PM
Probably not, but it doesn't sound like you have much choice.
Posted 24 November 2006 - 11:02 PM
you will porberly kill the cv joint but the hub should be ok
dave
dave
Posted 24 November 2006 - 11:05 PM
Thats great, I didnt want to waste time trying to get it out if I had to buy both units anyway.
Thanks Guys.
David
Thanks Guys.
David
Posted 24 November 2006 - 11:13 PM
I don't know how mechanicly inclined you are but,
have you detatched the hub at the top and bottom swivels? if not the drive shaft will stop the CV going back enough.
assuming the bearing has become stuck on the CV (it does happen sometimes) put something against the end of the CV to help prevent the thread being damaged (brass bar or a copper mallet is ideal, NOT THE NUT!!) and give it a damn good beating, the CV will probably exit with the inner bearing race(s) stuck on it, with an angle grinder carfuly grind through one side of it you should then be able to lever/pry/chisel it off leaving the CV hopefully unscathed.
Edited by mini13, 24 November 2006 - 11:13 PM.
Posted 24 November 2006 - 11:35 PM
Hi Mini13,
Thanks for your reply
I am a qualified mechanic, normally with this job, it takes me longer to get my tools out and put them away.
I am going to put a piece of wood over the thread.
David
David
Posted 24 November 2006 - 11:51 PM
Fair enough,
basicly the only bit that can get knackered is the thread on the end of the CV apart from that it's pretty straight forward.
Posted 25 November 2006 - 11:47 AM
Put the nut back on the end of the driveshaft so it is fully flush with the end of the threads. You are then hitting the nut and the threads at the same time and less chance of damaging each !
