Thank you.
Dangling Connector
Posted 03 October 2025 - 02:15 AM
Thank you.
Posted 08 October 2025 - 02:31 PM
I can only guess but 1992 SPi minis had a switch at the throttle pedal that told the EUC that it was "open". Have you checked towards the top of your pedal to see if there is a switch and if it's connected to anything?
Posted 12 October 2025 - 02:50 AM
It doesn't seem to be that as the car doesn't have a pedal input switch. Plus this connector looks too different from the input switch connector.
Edited by kbn4vi, 12 October 2025 - 02:54 AM.
Posted 12 October 2025 - 10:06 AM
The wire colours should tell you. Black is earth, that suggests a switch or sensor as an input or perhaps illumination. But why 4 connections that suggests a dpst switch?
Posted 12 October 2025 - 05:24 PM
no clueThe wire colours should tell you. Black is earth, that suggests a switch or sensor as an input or perhaps illumination. But why 4 connections that suggests a dpst switch?
Posted 13 October 2025 - 07:06 PM
What are the wire colors exactly?
Posted 18 October 2025 - 06:01 AM
green and blackWhat are the wire colors exactly?
Posted 18 December 2025 - 04:35 PM
I have the same dangling connector on my 1998 JDM cooper. I believe it could be for the catalyst overheat buzzer.
Posted 19 December 2025 - 01:16 PM
only have diagrams for uk spec. cars those colours are for radio ignition supply. and from fuse for reverse switch, indicators and heated rear window. Are there any options not fitted to your car?
