Carpet 1979 1275 Gt
Kevybmini
, Oct 10 2025 10:29 PM
Best Answer Kevybmini , 19 December 2025 - 02:55 PM
I bought the multi piece moulded one from Minispares (Newton Commercial) obviously I had to trim every piece but looks really good.
Go to the full post
3 replies to this topic
Posted 10 October 2025 - 10:29 PM
Hi all, looking for a new carpet. Where do you recommend and is it worth paying for the moulded ones which are way more money. Looking for the ones that come in many pieces - not the MPI 1 piece one.
Recommendations appreciated.
Posted 11 October 2025 - 10:34 AM
I didn’t like the moulded one. In the end I fitted the felt underlay set you can get to every surface in the cab with a dab of contact adhesive here and there, on top of that I fitted 10mm foil backed self adhesive closed cell foam, and taped the joints with foil tape and finally I used a cheap carpet set from Moss for about £50, with a little bit of contact adhesive needed on the front arches and the small vertical panels under the back seat. All that made the cab very acceptably quiet and after 5 years still looks good.
Posted 11 October 2025 - 08:22 PM
Mmm thats an interesting solution - the underlay is already in place.
Posted 19 December 2025 - 02:55 PM Best Answer
