Bonnet To Scuttle Gap - How To Improve
5 replies to this topic
#1 CBJ805T
CBJ805T
  • 459 posts
Posted 23 October 2025 - 03:11 PM
Hi - I'm trial fitting my front end.
I can get a nice gap ( £1 coin) between the bonnet and the scuttle, but when I try and open the bonnet, the bonnet return in the center (literally on the center line) of the bonnet catches the scuttle.
To prevent this, I need to open up the gap to 4-5mm
Can tips on how to improve this?
The bonnet brackets are fitted to the rearmost hole on the bulkhead bracket
thanks
Chris
#2 gaspen
gaspen
  • 1,192 posts
Posted 23 October 2025 - 07:18 PM
Which one is the rearmost hole ? There is only 1 hole (per side) for the bonnet hinge.
I think 4-5 mm gap is pretty good.
#3 sonscar
sonscar
  • 3,230 posts
Posted 23 October 2025 - 07:49 PM
Bend the return into a more acute angle,does the curve of scuttle and bonnet match?Steve..
#4 red81
red81
  • 63 posts
  • Local Club: Pembrokeshire Mini Club
Posted 24 October 2025 - 08:03 AM
Hi Chris
I don't think the manufacturing tolerances of budget British cars were that good in the day, if you can get it to 4-5mm that's really good, you should see mine!
#5 CBJ805T
CBJ805T
  • 459 posts
Posted 24 October 2025 - 11:49 AM
Thanks guys - I was aiming for a £1 coin :-)
If you're saying 4-5mm is good, then presumably this is bigger than the gap between the wing and the scuttle? i.e as you look across the car, the gap between the wing / scuttle and bonnet /scuttle are not the same?
#6 IronmanG
IronmanG
  • 1,361 posts
  • Local Club: Box hill. Lsmoc member
Posted 25 October 2025 - 08:15 AM
Have you definitely got the correct bonnet hinges. I had a nightmare with mine. I had to leave the wipers off to open the bonnet. I changed the hinges as there are about 4 different designs and magically a perfect gap and it opens nicely
