Fitting Doors
9 replies to this topic
#1 Propshaft
Propshaft
  • 165 posts
Posted 10 November 2025 - 08:08 AM
I am about to try and reduce my door gaps when welding a rod onto the door edge is it continuously welded or just stitched ie every half inch then filled over and profiled . Thanks
#2 shera12
shera12
  • 46 posts
Posted 10 November 2025 - 10:06 AM
Fitting doors can be a bit of a mission, especially if it’s your first time doing it! Just take your time lining everything up. Hinges and wiring can be somewhat challenging. Having an extra pair of hands really helps, too. Once it’s on, make sure the gaps are even and the door shuts smoothly before tightening everything up. It’s a satisfying job once you get it right!
#3 Cooperman
  • 23,559 posts
Posted 10 November 2025 - 11:17 PM
I have not done that for many years, but it is a good fix when the door gaps are excessive.
I welded it for its full length, doing a bit at a time to avoid it overheating and distorting. Then I linished back the welds and added a kiss of filler to get it right.
I guess you could stitch it, say 1/2" of weld and a 1" gap, or something similar.
Good luck with this.
#4 Steam
Steam
  • 943 posts
  • Local Club: Victorian Mini Club
Posted 11 November 2025 - 08:14 AM
Soumds like a lot of work for little gain to me.
#5 bpirie1000
bpirie1000
  • 2,549 posts
  • Local Club: Amoc
Posted 11 November 2025 - 05:06 PM
Pound coin rule for me....
Quid at the top gap, quid at the bottom gap and work to that rule.
Time now and you will be chuffed for the rest of your ownership.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,180 posts
  • Name: Neil
Posted 13 November 2025 - 08:20 PM
I stitched mine on Paddy then fully welded a couple of inches then moved on. HOWEVER i was using Frosts Cold Front to minimise distortion. I did end up with a little distortion but i should have been more patient. And yes pound gaps all round. I even did this to the boot lid which i had reskinned as well. Dont leave any of it unwelded, it will crack at somepoint unless you lead load.
OTT but hey its my car and its WHAT I WANTED to do.
#7 sonikk4
sonikk4
  • 16,180 posts
  • Name: Neil
Posted 13 November 2025 - 08:35 PM
New skin fitted and back in the hole. Door marked where welding rod will be required.
2d14938938b578c14c568d2f267dfff6d1393c1c
First lot of filler rod
a9df95d6262eb896574ae81b82aaa3150de86a6c
2nd lot of filler rod
5d9ae2eab2c7eeaef74a5376e60326fcc77f8574
Lots of Cold Front
8f2f343f2c5ecf1551b80db2d8d9ef1883342052
Finished result
9f5e4d9beccded40592431cd9544eb5e76af07d9
#8 sonikk4
sonikk4
  • 16,180 posts
  • Name: Neil
Posted 13 November 2025 - 08:38 PM
Front of the door with A panel and wings pinned in place. I had to rework the replacement A post return as well to get the A panel to fit nicely.
6a56d88defc065ef484546c500840694876f78b8
#9 bpirie1000
bpirie1000
  • 2,549 posts
  • Local Club: Amoc
Posted 14 November 2025 - 05:52 AM
Good job, well done..
But are you happy with the result?
How does it look with the door open?
#10 sonikk4
sonikk4
  • 16,180 posts
  • Name: Neil
Posted 14 November 2025 - 03:55 PM
Are you referring to my post or the OP?? If my post then you will have seen the finished painted results in my signature.
