hello all,
this winter i plan on making some improvements to my engine bay. The engine will remain in situ as i have no lift, and no where to store it, but i can see rust maybe surface creeping in around where the master cylinder bolts to, and where the relays attch etc. the repaint will be rattle can and this is due to finances (moving flat soon).
At NEC last weekend i got some wire wheels for both drill & angle grinder and im confident that the wire wheels for the drill will be most appropriate.
However i had seen a lot of primer options, red oxide etc and didnt want to purchase the wrong ones. I really want to make a decent effot despite the purse strings a little tighter than normal.
i have purchased Bilthamber rust corrective, but to prevent rust re-occuring and this would help knowing when panels need replacing, what protective measures can i use before final paint. im confident that i will remove old paint rust down to bare metal and when treated with rust prevention, what else woudl be recommended.
This will be a slow slog, i want to clean all wiring, relays repaint block, etc so time isnt of the essance.
any handy tips, advice is always welcome :)
