Sill Reinforcement Bracket
5 replies to this topic
#1 knowell
knowell
  • 31 posts
Posted 01 December 2025 - 07:15 PM
I am replacing floor pan and will replace the inner sill
Portion that comes with the panel. After cutting out the inner sill I came across the sill reinforcement bracket. Is it necessary to retain this? Feels like it doesn’t add much. Watching videos of others doing the exact same repair I can’t seem to find a good shot of them plug welding to it. Seems like it’s just cut off. Appreciate any info
Replacement part
[https://www.minispar...l-bracket-front
Edited by knowell, 02 December 2025 - 04:02 AM.
#2 sonscar
sonscar
  • 3,257 posts
Posted 01 December 2025 - 07:29 PM
They put it in so there must have been a reason?The door post is fairly heavily loaded with the door and the crossmember ends and it adds triangulation.Just my opinion.Steve..
#3 stuart bowes
stuart bowes
  • 2,646 posts
Posted 01 December 2025 - 08:02 PM
agree, if it was there before, put one back in.  minis are not strong shells as they are let alone taking anything away in a critical place like that
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
It was there as part of the slinging bracket assy. Does it play a part in adding strength, yup for that particular reason. But is it now needed, well thats a question for deabte.
I bin mine off along with the external slinging brackets. Stops the unwary from using then a jacking point. As an aside to this i still keep the internal jacking bracket as i still use the OE jacking point.
Just to add, its held in place with just a couple of spot welds so exactly how much strength does it add??
#5 mab01uk
mab01uk
  • 13,086 posts
Posted 01 December 2025 - 08:06 PM
The Slinger Brackets linked below, that your Minispares 'Sill Reinforcement Slinger Bracket' link above also refers to says: "only purpose was for building/moving/ storing and preparation of cars at the factory to sit them on...Also acted as a stiffener between the inner and outer sills which is why the factory fitted them to stop damage."
Slinging Bracket Rear:-
https://www.minispar...racket-l-h-rear
Slinging Bracket Front:-
https://www.minispar...g-bracket-front
Many people remove the Slinger Brackets during sill replacement or restoration (unless originalty is important) as they are not used after the factory assembly lines....but are often confused by tyre fitters as trolley jacking points which usually bends them and/or damages the floorpan. I personally doubt the sill reinforcement bracket does much after the factory assembly use of the Slinger Brackets has finished.....although it might help a little if, as said above, a tyre fitter uses a trolley jack on the slinger bracket below it!
Edited by mab01uk, 01 December 2025 - 08:14 PM.
#6 knowell
knowell
  • 31 posts
Posted 01 December 2025 - 09:58 PM
Just to add, it’s held in place with just a couple of spot welds so exactly how much strength does it add??
That’s my thoughts after detaching the one side it wiggles pretty freely. Thanks for the insight
Edited by knowell, 01 December 2025 - 10:00 PM.
