right, is there a way to link my right hand tank to an injection tank?
if not can anyone suggest which fuel pump would be ideal for a turbo engine? does a turbo engine have to have a return? (i have both a injection and carb 7.5 gallon lefthand fuel tanks)
anyone whos good on ms paint to draw me a quick diagram would be helpful
linking an injection tank to a righthand tank
steveobennet
, Nov 25 2006 02:03 PM
5 replies to this topic
Posted 25 November 2006 - 02:03 PM
Posted 25 November 2006 - 08:10 PM
if its any help to you mate i am going to add a t piece in between the two tanks to see if it will work
i am using the spi tank aswell
Posted 25 November 2006 - 08:15 PM
to link an spi tank to a right hand tank i think you'll need to put in another pipe at the bottom of the spi tank!!
its possible to t-piece it with the std tank and put a high flow external pump on the recieving end of the t-piece! you will need a return line tho to 1 of the tanks!! from the presure regulator!!
Posted 25 November 2006 - 10:59 PM
would it be easier to use my existing carb tank (lefthand one) and use an exteranl pump? any suggestions on which pump i should use? miniturbo if you could keep me posted and let me know what happens, thanks
Posted 25 November 2006 - 11:29 PM
Posted 25 November 2006 - 11:31 PM
you could have a look on ebay for a metro turbo fuel pump or try www.turbominis.co.uk
i have used this site a lot for all help on mine
if you are going to use a normal petrol tank then make sure you have a return to the tank from the fuel regulator
