Mini Pickup Fuel Filler Neck Hole Measurements Needed.
6 replies to this topic
#1 Furyan
Furyan
  • 177 posts
Posted 04 December 2025 - 01:40 AM
Does anyone have a drivers side mini pickup panel, or indeed a mini pickup that you could measure the hole for the triangle shaped fuel filler neck?
My pickup has had the original hole welded over by a square plate as a previous owner was going to use it as a track car with a fuel cell in the back so I can't see where the original hole was.
I have the triangle shaped filler neck and can make a template of the actual shape of the hole needed from that but I need a measurement or two to get me started.
The measurements I need are the distances marked by the yellow lines on the photo attached.
Appreciate any help offered, cheers to all.
Attached File  pickup side2 (another copy).png   29.89K   4 downloads
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 04 December 2025 - 12:23 PM
I have an old Mini Van shell that I could measure.
#3 Furyan
Furyan
  • 177 posts
Posted 06 December 2025 - 07:35 AM
I think the mini van panel angles up from the bottom bumper area to the roof whereas the pickup panel goes vertical from bottom to the top so the horizontal measurement I need from the bottom corner of the fuel filler to the seam might not be the same twixt van and pickup  :unsure:
The height measurement from the bottom seam to the fuel filler might be the same though, so yes please if you could measure them both that would be great, it should get me in the ball park area anyway, many thanks DeadSquare.
#4 Ethel
  • 26,822 posts
Posted 06 December 2025 - 02:07 PM
Same rear scuttle, so same seam. Do you have a tank? Working off that may be safer. Make a template to put the hole in the floor, if there isn't one.  You ought to then be able to pattern up the tank well enough to make your mark off the filler neck.
#5 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 06 December 2025 - 05:57 PM
I can get it to you tomorrow
#6 IronmanG
IronmanG
  • 1,363 posts
Posted 07 December 2025 - 01:42 PM
135mm top to bottom.
52m left to right.
#7 Furyan
Furyan
  • 177 posts
Posted 09 December 2025 - 04:17 AM
Many thanks Ironman G it's much appreciated  :thumbsup:,thanks to all for the reply's and advice and wishing you all a Merry Christmas  :xmas:
