Firewall
6 replies to this topic
#1 DGO129
DGO129
    Starting My Mini Up
  • 2 posts
Posted 14 December 2025 - 02:00 PM
Hi all,
If anyone still reads this section - I acquired an unfinished early Zcars Busa mini which I am prepping for IVA - does anyone know what thickness aluminium Zcars used for the firewall. I can't find any specifics in the IVA blurb. I was thinking 2mm sheet would suffice?
Also any suggestions on collapsible steering columns - the "wearediminutive.com" setup looks elegant but I can't make out what components they used?
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 14 December 2025 - 02:39 PM
It was after was a saloon car fire in the mid 1960s, that the RAC immediately introduced a "Fire-wall" which became mandatory for club racing in the UK.  The scrutineers demanded that "Fire-Gaps" were filled with 1/16" steel if the car was of predominately steel construction.  Exotic cars with more than 25% aluminium, could use 10 gauge (Just over 1/8")  aluminium.
I remember at Brands Hatch, a furious row when a scrutineer refused to pass a car because there was no mention in the emergency regulation about Fibreglass construction.
#3 quagmire
quagmire
  • 78 posts
Posted 14 December 2025 - 08:30 PM
going to use 3mm ali on mine bit more difficult to work with but a lot more ridgid once its fitted i would have thought
#4 DGO129
DGO129
    Starting My Mini Up
  • 2 posts
Posted 15 December 2025 - 02:28 PM
Thanks for responses - think I will up it to 3mm then
#5 Will_they_run_again
Will_they_run_again
    Just On Tickover
  • 7 posts
Posted 05 January 2026 - 05:32 PM
i assume you are talking about behind the seats ?, mine had ( i binned it as it was rubbish and will be redoing it ) and others i have seen from them used a honeycomb aluminum panel with an access hatch in the middle.
#6 Painter man
Painter man
  • 90 posts
Posted 15 January 2026 - 07:40 PM
I have 4 mm in mine fitted with busa gen 2 it will be at mini fair 2026 on the 25th of this month if you want to pop see me on the fast lads stand thanks craig 07967 575286
#7 Ethel
  • 26,757 posts
Posted 17 January 2026 - 12:49 AM
There must be way more variables
If you're not a chief constable, Google's AI says Locost builders use 1/8" ally plate & think IVA testers must see plenty of them.  Seems like overkill to me, unless it's load bearing. 1mm of ally was good enough to shoot rapids in before canoeists discovered HDPE
