Gt1752 On Fusion Fabs Manifold
4 replies to this topic
#1 coopertaz
coopertaz
  • 932 posts
  • Local Club: a-series-magpies
Posted 16 December 2025 - 11:13 AM
how have people routed the cooling system for this, have had head dry decked and was thinking take off from head heater port then back from turbo to sandwich plate at thermostat does this work? also for oil feed what restrictor, if any, do you need on supply from banjo coupling to turbo? draining back through redundant fuel pump aperture.
#2 Steve220
Steve220
  • 5,138 posts
  • Local Club: BMC
Posted 27 December 2025 - 12:31 PM
That cooling won't work. Yes, take it from the heater port on the left, then route it back before the water pump.
You don't need an oil restrictor for a journal bearing turbo. Drain back, you can use the fuel pump aperture using a relative fitting. It maybe tight though.
#3 coopertaz
coopertaz
  • 932 posts
Posted 30 December 2025 - 10:23 AM
thanks for reply on this but before water pump! so into bottom hose? wont that just bypass radiator so cause overheating.
Edited by coopertaz, 30 December 2025 - 10:24 AM.
#4 Steve220
Steve220
  • 5,138 posts
  • Local Club: BMC
Posted 30 December 2025 - 02:47 PM
Not really as the turbo acts as a restriction, so the majority of the coolant goes through the engine
#5 coopertaz
coopertaz
  • 932 posts
Posted 31 December 2025 - 11:38 AM
thanks will be fitting larger rad and oil cooler too anyway,
