Mpi Error Codes
5 replies to this topic
#1 Ledlights
Ledlights
  • 19 posts
Posted 27 December 2025 - 09:21 AM
I read the error codes for my daughter's car using the excellent Rover MEMS web app and came across a couple of errors:
Fault - Oil Temperature (high voltage)
Fault - Oil Temp (present)
Fault - Outside air temp (low voltage)
Fault - Outside temp sensor (present)
Would I be right in thinking the oil temperature error was caused by a fault related to this sensor? https://www.minispar...er-for-97on-mpi
The air temperature is a bit more tricky as there doesn't appear to be an outside temperature sensor but it might relate to the inlet air temperature (https://www.minispar...ction-green-top) - does this sound plausible?
Any advice gratefully received...
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 27 December 2025 - 12:28 PM
All of them aren't relative to the MPI. Oil temp doesn't go through the ECU, and there is no outside air temp sensor on minis.
#3 mab01uk
mab01uk
  • 12,914 posts
Posted 27 December 2025 - 03:53 PM
Mini Mpi Diagnostics - Car Mechanics Magazine:-
https://www.theminif...anics-magazine/
Edited by mab01uk, 27 December 2025 - 03:53 PM.
#4 Ledlights
Ledlights
  • 19 posts
Posted 28 December 2025 - 08:34 AM
So from this article, could the outside air temperature code be pointing at a fault with B41 - the inlet manifold temperature sensor?
#5 theoldmini
theoldmini
  • 159 posts
Posted 21 February 2026 - 04:42 PM
Trying to use the rovermems.com off the net.  Have loaded cable driver obd lights up plug into laptop and nothing showing.  Help needed
#6 68+86auto
68+86auto
  • 1,333 posts
  • Local Club: Queensland Mini Car Club
Posted 22 February 2026 - 03:12 AM
Just test all the sensors without reading the ECU and then you won't be mislead.
