Carb Fuel Leak
Best Answer sonscar , 08 February 2026 - 04:18 PM
Jet pipe? The LHS bit is the jet which moves up and down with the choke.The plastic pipe has a small washer and rubber seal held in by the nut.Be gentle with the nut.Steve.. Go to the full post
11 replies to this topic
#1 MiniGuy1990
MiniGuy1990
  • 13 posts
Posted 08 February 2026 - 03:54 PM
Afternoon All!
After changing the exhaust manifold and exhaust on my mini, I came to bolt it all back up and have discovered a significant fuel leak from my carb. I will attach pics to show where this is coming from. Being rather new to all this, I don’t even know what to search online to find this particular part so any help is appreciated!
#2 MiniGuy1990
MiniGuy1990
  • 13 posts
Posted 08 February 2026 - 03:56 PM
Photo of the leak point
#3 sonscar
sonscar
  • 3,199 posts
Posted 08 February 2026 - 04:18 PM   Best Answer
#4 mab01uk
mab01uk
  • 12,927 posts
Posted 08 February 2026 - 06:54 PM
SU Waxstat Jet Assembly:-
https://sucarb.co.uk...ly-090in-1.html
Minispares:-
https://www.minispar...e-late-mini-hs4
https://www.minispar...tat-tye-for-hs6
Note: If you do need a replacement jet assembly you would need to input the correct year of Mini and SU Carb part number into the Burlen website, as the above parts are just quoted by me as examples:-
https://sucarb.co.uk...is&vehicle=Mini
Edited by mab01uk, 08 February 2026 - 07:04 PM.
#5 Gaz66
Gaz66
  • 1,148 posts
Posted 08 February 2026 - 07:08 PM
Or....get this as its at least 60 quid cheaper 😁
https://www.minispar...float-bowl-seal
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 09 February 2026 - 10:06 AM
Or a waxstat conversion for £20
#7 Ethel
  • 26,583 posts
Posted 09 February 2026 - 10:39 AM
A waxstat conversion is 1p.  ;D
#8 68+86auto
68+86auto
  • 1,348 posts
  • Local Club: Queensland Mini Car Club
Posted 09 February 2026 - 10:36 PM
That won't solve the problem though.
#9 Ethel
  • 26,583 posts
Posted 09 February 2026 - 11:32 PM
Nope, only a flux capacitor, so you go back & buy petrol without ethanol would really do that.
#10 MiniGuy1990
MiniGuy1990
  • 13 posts
Posted 10 February 2026 - 06:17 AM
Thanks all that’s really helpful.
Worryingly, when I removed that nut, I found the metal washer but there’s no rubber one in site. How can it have been fitted without it?
#11 Ethel
  • 26,583 posts
Posted 10 February 2026 - 01:11 PM
If you haven't, make sure it's not still in the screw hole. It might not look like an O ring any more.
#12 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 10 February 2026 - 06:43 PM
Well done for getting stuck in and giving it a go..
Bravo...
