Carb Fuel Leak
Best Answer sonscar , 08 February 2026 - 04:18 PM
Jet pipe? The LHS bit is the jet which moves up and down with the choke.The plastic pipe has a small washer and rubber seal held in by the nut.Be gentle with the nut.Steve..
Go to the full post
Posted 08 February 2026 - 03:54 PM
After changing the exhaust manifold and exhaust on my mini, I came to bolt it all back up and have discovered a significant fuel leak from my carb. I will attach pics to show where this is coming from. Being rather new to all this, I don’t even know what to search online to find this particular part so any help is appreciated!
Posted 08 February 2026 - 03:56 PM
Posted 08 February 2026 - 04:18 PM Best Answer
Posted 08 February 2026 - 06:54 PM
SU Waxstat Jet Assembly:-
https://sucarb.co.uk...ly-090in-1.html
Minispares:-
https://www.minispar...e-late-mini-hs4
https://www.minispar...tat-tye-for-hs6
Note: If you do need a replacement jet assembly you would need to input the correct year of Mini and SU Carb part number into the Burlen website, as the above parts are just quoted by me as examples:-
https://sucarb.co.uk...is&vehicle=Mini
Edited by mab01uk, 08 February 2026 - 07:04 PM.
Posted 08 February 2026 - 07:08 PM
Posted 09 February 2026 - 10:06 AM
Posted 09 February 2026 - 10:39 AM
A waxstat conversion is 1p. ![]()
Posted 09 February 2026 - 10:36 PM
That won't solve the problem though.
Posted 09 February 2026 - 11:32 PM
Nope, only a flux capacitor, so you go back & buy petrol without ethanol would really do that.
Posted 10 February 2026 - 06:17 AM
Worryingly, when I removed that nut, I found the metal washer but there’s no rubber one in site. How can it have been fitted without it?
Posted 10 February 2026 - 01:11 PM
If you haven't, make sure it's not still in the screw hole. It might not look like an O ring any more.
Posted 10 February 2026 - 06:43 PM
Bravo...
