I’Ve Messed Up Fitting My New Wing
10 replies to this topic
#1 CBJ805T
CBJ805T
  • 459 posts
Posted 17 February 2026 - 06:45 PM
Hi all
Bad day in the garage - I was fitting my new driver side wing and having initially tacked the wing near the bonnet hinge, I was wrestling with trying to get the front panel to fit properly against it. having got the fit where I wanted it I welded it in place and then welded the a panel onto the wing. When I stood back I realised I’d not positioned the panel properly against the scuttle. the photos show the gap I’m left with, which is around 3 -4mm. My question is can this be fixed? If so, how or do I need to cut the wing off buy a new one and start again?
https://www.amazon.c...qVeebsVj2exJDpK
https://www.amazon.c...AGer0LmWwmI66YL
https://www.amazon.c...kJYor2ZEnJ0TUWY
Bonnet Fit -
The bonnet fit is 4mm all round - but it gets tighter at the front panel on the drivers side
https://www.amazon.c...E31vfsEV6xyEKva
https://www.amazon.c...ywvDbLKm9In6LUh
Other Wing Fit: - Gap is 2mm, 3mm max
https://www.amazon.c...mM5qBcFlPy4k7bI
Front Panel / Bonnet / Wing:
Passenger - https://www.amazon.c...5QR257sA7ou3PhD
Drivers - https://www.amazon.c...PRhmmPLf6JufiDa
Edited by CBJ805T, 19 February 2026 - 10:10 AM.
#2 Gaz66
Gaz66
  • 1,201 posts
Posted 17 February 2026 - 07:00 PM
Thats as good as ive ever seen on a mini. A smear of seam sealer, job done 👍
#3 sonscar
sonscar
  • 3,257 posts
Posted 17 February 2026 - 08:59 PM
I'd be happy with that.Steve..
#4 Minirook
Minirook
  • 53 posts
Posted 17 February 2026 - 11:01 PM
If you have not done this yet, Fit the hood (bonnet)  on and see how everything aligns before making a final decision here. You didn't say that the passenger side was on already. I everything aligns then how is a new one going to improve fitment. It's at this point I would consider using a sealer on the joint.
Based on the second set of pics, I would be happy with what I see. Good alignment on the hood, front panel and Outer A post. At the end of the day if you are happy, then a nice sealant job at the joint will wrap it up. If you are not happy with it, start again, just know you are chasing 1 to 2mm improvement.
Edited by Minirook, 18 February 2026 - 02:10 PM.
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,568 posts
  • Local Club: Amoc
Posted 18 February 2026 - 11:04 AM
Are these genuine wings and scuttle?
Fettling in every panel is always required.
I usually say.. get to a good point then leave it... return later.. fresh eyes..
Over think things until you return..
Time spent now pays dividends later..
#6 CBJ805T
CBJ805T
  • 459 posts
Posted 18 February 2026 - 12:39 PM
I've added some more photos of the bonnet fit and other wing to the original post
All panels are heritage and more importantly already welded in  :unsure:
Edited by CBJ805T, 18 February 2026 - 12:39 PM.
#7 Gaz66
Gaz66
  • 1,201 posts
Posted 18 February 2026 - 02:38 PM
Personally I wouldnt be worried about any of that 👍
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 18 February 2026 - 04:27 PM
to be honest i have seen far worse and some so called professional fits as well.
NOW if you are really getting skewed out of shape about this then your only option other than to rip the wing off and start again is to slot the wing where iit curves around the scuttle, dress if back till you are happy with the gap, then weld in a thin strip of metal. Linish it all up, skim of plop, jobs a good un.
A lot of work, very doable (did this to a Magnum panel on my mates mainstream Cooper) but time consuming.
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,568 posts
  • Local Club: Amoc
Posted 18 February 2026 - 08:06 PM
What you using the car for is key here.... Concours or just to enjoy...
It is what it is.. consistent gaps... all that most people try for..
#10 coopertaz
coopertaz
  • 949 posts
  • Local Club: a-series-magpies
Posted 20 February 2026 - 12:12 PM
yes not concourse but very good and would leave as is. as above seam sealer or run some braze in it, if you have the kit.
#11 CBJ805T
CBJ805T
  • 459 posts
Posted 20 February 2026 - 04:30 PM
Hi All,
thanks for your feedback - you've cheered my up and I thought it was rubbish but you've all said it was ok
I'll add some seamsealer and move on
Appreciate your input
Chris
