Mpi Crank Sensor Removal
3 replies to this topic
#1 bogstandard
bogstandard
  • 56 posts
Posted 17 February 2026 - 08:28 PM
Hello Mini Friends,
Been an awful last 12 months after getting the car back from body work restoration and the car idle for 3 years. It has spent more time on the back of a trailer this year rather than on the road. Constant electrical issues with engine cutting out when hot then starting again when cooled down. Engine electrics been cleaned up a lot and when I keep thinking it's solved it goes again. Currently cranking and no start. Last time it went smoke coming out of clutch/flywheel housing so hoping the final thing to fix is the Crank Sensor.
Picture attached (hopefully) of it and in a tight space and cannot get anything to grip the nut/hex screw as it's rounded and flat on top. I'm looking at more tools to make a bad situation worse but don't know where to go from here. Any suggestions welcome.
Thank you all.
#2 sonscar
sonscar
  • 3,214 posts
Posted 17 February 2026 - 08:56 PM
Last resort if the new one is the same.Unplug it and break up the plastic and mole grips.Try hammering on a slightly smaller socket.Steve..
#3 Ethel
  • 26,657 posts
Posted 17 February 2026 - 08:59 PM
Have you taken the grille off? That will help access. A hex socket and a decent length extension bar would help to turn it without levering the head at odd angles
... You could unbolt the starter motor, it's only 2 bolts
#4 68+86auto
68+86auto
  • 1,391 posts
Posted 17 February 2026 - 11:55 PM
If smoke was coming out, you've got a problem which isn't the crank sensor.
