Coolant Expansion Tank: Where And How To Mount?
Best Answer NLinPEN , 28 February 2026 - 06:22 AM
Thank you all for your help with this topic. I have been able to repair the cracks in the tank and install it the correct way above the front left wheel. Then I undid the hose near the radiator cap and filled the overflow bottle with about 0.5 litres of coolant (I estimate its full capacity is close to one litre). I left the radiator not entirely full, on purpose. Then took it for a test drive, made sure that the engine got properly warm. The following day, after all pressure had gone from the system, I confirmed that some of the coolant had been "sucked" from the overflow bottle into the radiator to fill it up completely. This is what I expected as it proofs that the coolant system does not have a leak. And that the radiator cap works as intended: both its over-pressure valve as well as its one-way valve functions.
I consider this topic closed.
Go to the full post
24 replies to this topic
#1 NLinPEN
NLinPEN
  • 168 posts
Posted 18 February 2026 - 08:56 AM
I am not sure whether my question is specific to the SPI model, or applies to all (newer) versions of the Mini. The car had a coolant overflow tank (a.k.a. expansion tank) mounted in the left front wheel arch. However, this was a bit of a botch job by a previous owner: the tank was dangling by a piece of metal wire from the fresh air hose that goes to the vent in the dashboard. This held up until it didn't: the air hose came loose under the weight of the tank, the tank came down and got stuck between the wheel and suspension. I am not sure whether this tank is original to the SPI model, or some aftermarket model.
Obviously I want to mount this tank properly. But I can not find a clear drawing or photo on where it is supposed to be mounted, and how it is to be mounted. What is the correct location? What kind of brackets do I need? How is this tank mounted to the car's body?
If anyone has a drawing, or some photos of how it is mounted I would appreciate it.
#2 MikeRotherham
MikeRotherham
  • 1,026 posts
Posted 18 February 2026 - 09:20 AM
The tank is original to Spi and later carburettor models.
Here is a link to one on Ebay with a number of images of what the tank should look like and how it sits under the wing:
https://www.ebay.co....tm/256974127982
The threaded bolt is secured through the bulk head by a nut.
To use this tank you also need the correct radiator cap which allows coolant to enter and leave the expansion tank.
Edited by MikeRotherham, 18 February 2026 - 05:06 PM.
#3 Quinlan minor
Quinlan minor
  • 1,359 posts
Posted 18 February 2026 - 09:38 AM
As above.
Edited by Quinlan minor, 18 February 2026 - 09:39 AM.
#4 Ethel
  • 26,698 posts
Posted 18 February 2026 - 10:25 AM
Here's a piccy of one snuggled in
Note the hose is at the bottom so coolant can be sucked back when it cools. It has a fill level for the same reason.
The radiator cap, mentioned above, has 2  rubber seals: 1 between the cap itself & the filler neck as well as the spring loaded one.
#5 NLinPEN
NLinPEN
  • 168 posts
Posted 19 February 2026 - 02:29 PM
Thank you for this: it is very useful. The photos confirm that I do have the original expansion tank (PCF10097) on my car. Which makes me wonder why the previous owner(s) did not mount it in its intended position. Those photos on eBay show that it sits on a bracket and is located next to a black canister (isn't this emissions-related?). That black canister is present in my car.
Due to the tank getting stuck between the wheel and the suspension did it get mangled. But I am not sure if this has made it unusable. There is a crack near the top of the tank, see photo #1. Photo #2 shows more mangled-ness, but no other cracks. I don't know whether this expansion tank operates under pressure, or that it is at atmospheric pressure (e.g. an overflow bottle). Having to make this airtight would be a bigger job then just slapping some duct tape on it.
  • Attached File  1.jpeg   36.01K   3 downloads
  • Attached File  2.jpeg   31.35K   2 downloads
#6 NLinPEN
NLinPEN
  • 168 posts
Posted 19 February 2026 - 02:31 PM
Thanks for your comments related to the radiator cap. I will check whether mine is the correct one.
#7 Ethel
  • 26,698 posts
Posted 19 February 2026 - 08:28 PM
That has been in the wars  >_<
I'd guess the black buttony shaped bit, on the top by the bracket is a pressure relief valve of sorts. It looks pretty basic so may only be intended to avoid the tank going bang as a last resort. You could try and rig up a test rig with a foot pump to if tank is battered but functional. Anything a few psi over the radiator cap will likely do
#8 MikeRotherham
MikeRotherham
  • 1,026 posts
Posted 19 February 2026 - 09:59 PM
I was never sure if the expansion tank was pressurised or not.
If it is the pressure must be very low.
The black 'bung' with a centre doesn't can't hold much pressure.
#9 NLinPEN
NLinPEN
  • 168 posts
Posted 20 February 2026 - 06:29 AM
The radiator cap has indeed two seals, and both look in good condition. They are not torn or damaged. The cap is rated for 88 kPa.
  • Attached File  3.jpeg   41.64K   1 downloads
#10 NLinPEN
NLinPEN
  • 168 posts
Posted 20 February 2026 - 06:31 AM
For now I'll assume that the cooling system will work with the tank being an overflow tank, at atmospheric pressure. Just like you I have my doubts about that black "overpressure valve". It looks rather flimsy to me.
#11 Ethel
  • 26,698 posts
Posted 20 February 2026 - 12:10 PM
It all depends on the relative water levels in the radiator & tank. I expect Rover had to fit it because of environmental regulations against squirting antifreeze out. It will do that, even if it can't recover lost coolant when it cools down. If the radiator as lost some of its contents it ought to get below atmospheric pressure when it has cooled, but the rubber hoses won't allow much. Vented steam would condense inside the bottle, which would drop the pressure a lot if it wasn't vented - I just can't see coolant making back from the tank to the radiator under gravity alone, the water level must be a fair bit lower.
0.9 bar is 13 psi the original cap was 15psi, but it'd only allow it to boil over at 118 C instead of 120 to 121 C. There are masses of similar looking radiator caps, so it could be worth some research to check it's for the correct filler neck height - if you have cooling problems.
#12 coopertaz
coopertaz
  • 915 posts
  • Local Club: a-series-magpies
Posted 20 February 2026 - 12:18 PM
presume for jap. spec, my 1995 spi and 1992 carb model had standard rad and both were low mileage original models when we got them. both did have the charcoal canister under the wing though
#13 NLinPEN
NLinPEN
  • 168 posts
Posted 20 February 2026 - 02:04 PM
To avoid that this thread is going into a different tangent: no, my car does not have cooling problems. I have tried my best to make it work hard and demonstrate any cooling problems in the hot Malaysian climate, but there simply aren't any.
#14 bangermadness08
bangermadness08
  • 283 posts
Posted 20 February 2026 - 06:44 PM
What is the correct cap for a 1995 spi?
#15 Ethel
  • 26,698 posts
Posted 20 February 2026 - 07:25 PM
Minispares say 15psi (yes, the stamping on the cap is more accurate)
