Aldon Automotive Built A Series 1380Cc
3 replies to this topic
#1 mini_wooly
mini_wooly
  • 0 posts
Posted 22 March 2026 - 07:06 PM
Aldon Automotive built 1380 A Series. Built in 1984 and never been ran (brand new). With original receipt/paperwork.
Spec:
Hepolite powermax pistons with lightened, balanced and polished rods.
Cooper S crank, webs lightened, bead blasted and balanced.
11 stud head, extensively gas flowed and polished with 36mm Rimflow inlet, 31mm Rimflow exhaust valves and double high lift valve springs.
Carbon fibre pushrods.
Avonbar 1.5 ratio rockers.
Piper 285 cam.
Triger cam belt conversion.
Ultralight flywheel with uprated clutch cover and plate, all balanced.
Aldon Automotive matched distributor.
Fully rebuilt gearbox.
Center oil pickup.
Engine to gearbox bolts enlarged to 5/16”.
Lucas electronic ignition.
The only downside is the gearbox could do with being repainted as it's flaked off.
I do have a few other bits that could go with it too if any are of interest.Open to negotiations with these:
AC Dodd cam with 1.3 rockers
Long Center Branch exhaust
Rubber coupling drive shafts
HIF44 and a manifold to go with. The carb needs the mods for venting (again, I can do this but open to negotiation)
Open to offers
Collection only from DY12
#2 mini_wooly
mini_wooly
  • 0 posts
Posted 22 March 2026 - 07:08 PM
Note:
If someone could guide me on how to add photos, that would be ideal.
#3 stuart bowes
stuart bowes
  • 2,618 posts
Posted 23 March 2026 - 11:33 AM
https://imgbb.com/
use it free, no account set up or payment, drag and drop pictures onto page, choose don't delete
choose 'bulletin board full' or whatever the option is, copy and paste the resulting code into a post here
#4 toby&pickle
toby&pickle
  • 10 posts
Posted 01 April 2026 - 01:45 PM
i'am a dinosaur with any tech.
