Coil Burn
3 replies to this topic
#1 gaspen
gaspen
  • 1,193 posts
Posted 26 April 2026 - 12:17 PM
Hi!
The picture shows the reason of my questions : what I did wrong ?
It is a freshly built 850, it never run a second. Powerspark 25D electronic dizzy with VC110 1.5Ohm coil
I'd liked to start it but there was no spark. Finally I found that the coil is faulty, it showed 4 ohm at the primary circuit and ~2 kOhm at secondary
I also noticed that the bottom of the coil housing has a "hump" so it became more evident that I burnt the coil somehow.
I would like to avoid this to happen so any advice is welcome
Attached File  20260426_133401.jpg   28.65K   0 downloads
#2 68+86auto
68+86auto
  • 1,454 posts
Posted 26 April 2026 - 01:07 PM
The ignition was likely left connected somehow.
Edited by 68+86auto, 26 April 2026 - 01:09 PM.
#3 Earwax
Earwax
  • 602 posts
Posted 26 April 2026 - 08:52 PM
As above but also adding the electronic dizzy may also be kaput.
#4 gaspen
gaspen
  • 1,193 posts
Posted 27 April 2026 - 04:53 AM
I have the same coil in my 998 so I put it in and it started immediately  :shifty:
https://photos.app.g...F9cwNQAFKYo9Ht9
