Magnum Scuttle
2 replies to this topic
#1 scb
scb
  • 53 posts
Posted 06 May 2026 - 01:09 PM
Title should be "Magnum scuttle" but I can't edit it.
Bought a couple of repair panels as my scuttle has a bit of rust at each end. They've arrived and they look like they have been squashed and pulled back into shape and just a bit crap.
Is this normal? Is this how they are? Or have might be damaged? If it was just one of them I'd say damaged, but it's both sides.
edit2> Just done what I should have done in the first places and searched the forum. Yeah, they're always crap. Shouldn't have bothered!
Edited by scb, 06 May 2026 - 01:15 PM.
#2 stuart bowes
stuart bowes
  • 2,609 posts
Posted 06 May 2026 - 01:21 PM
post a pic?  I use https://imgbb.com/ don't pay for anything just do it free
would probably have to do a bit of manipulating while fitting anyway, to make it fit right but that only goes so far
side note if you're cutting the ends off the scuttle might want to have a little gentle poke around up the top of the flitch panel, I had a bit of a nasty little hole growing there on mine, with the end off it's an ideal time to do the repair, getting at it from the inside is pretty much a no-go
trouble is you can't see that area from below because of the the closing panel
that last one isn't 'finished' by the way lol I just quickly mucked about with a skim of filler to get an idea of if it could be smooth enough
Edited by stuart bowes, 06 May 2026 - 01:24 PM.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 06 May 2026 - 04:42 PM
Changed the title for you.
And as for those end pieces, more trouble than they are worth to be honest and if they are rotted out what are the closeouts like
