Would You Run This Cam?
8 replies to this topic
#1 TheFlood
TheFlood
  • 10 posts
Posted 08 May 2026 - 05:58 PM
Hi
I have a NOS Minispeed CA4 (544 profile) camshaft and having a look at it today noticed that on three of the lobes there is a slight flat where it appears that the cam was not fully 'cleaned up' when being reprofiled.
Has anyone had experience with this before?  The flats are only slight, but if it is going to bite me later on I'd rather just replace the cam now. On the other hand, I'm guessing the cam passed quality control when it was manufactured and that I may be worrying for no reason.
Thoughts?
Attached File  1.jpeg   40.11K   14 downloadsAttached File  2.jpeg   40.86K   9 downloadsAttached File  4.jpeg   60.04K   4 downloads
#2 croc7
croc7
  • 875 posts
Posted 09 May 2026 - 07:32 PM
Send the pictures and text to Delta Camshaft in Tacoma, WA.  I've used them a lot to re-profile A Series engine camshafts, they are experts in the field and can give the advice that you need.
#3 TheFlood
TheFlood
  • 10 posts
Posted 10 May 2026 - 05:11 AM
I should be down that way soon, I'll see what they say.
#4 Earwax
Earwax
  • 574 posts
Posted 11 May 2026 - 09:49 PM
A bit late on the scene, and certainly no expert , but my thoughts none the less.
Most thorough way is to put it on a Cam DR   - but I do not think the originals had flat spots - and certainly not just on three lobes.  Total lift would be affected - but I doubt you would feel it , More of a concern is what impact it may have on the lifters over time ( especially if they are not faced properly. - if the cam is based on the 544 - it is a fairly high revving 'aggressive cam' -  so I would think about its use if on a road engine.
#5 Spider
  • 15,671 posts
Posted 11 May 2026 - 11:21 PM
I wouldn't run it.
#6 DeadSquare
DeadSquare
  • 3,375 posts
Posted 13 May 2026 - 01:21 PM
Send it back.
#7 croc7
croc7
  • 875 posts
Posted 13 May 2026 - 07:57 PM
Better call them first.  As stated by the owner, the increase in crime, graffiti and taxes has Delta Camshaft packing up and moving to Arizona.
#8 TheFlood
TheFlood
  • 10 posts
Posted 14 May 2026 - 04:55 AM
Thanks everyone.
I think the opinions have confirmed what I was thinking myself, I'm not going to run it. It can go into my "not good enough to run, but can't bring myself to put it in the trash pile'!  :lol:
#9 croc7
croc7
  • 875 posts
Posted 19 May 2026 - 01:21 AM
Thanks everyone.
Don't toss it, keep and have it re-ground to a profile suited to your style of driving.
