Hi all,
I will be taking my MPI engine for a rebore, I have 21253 pistons +20 and my machine shop, here in France, needs to know the piston to bore clearance and where it's actually meseared from on the piston.
Does anyone know ?
Pete.
Posted 17 May 2026 - 03:13 PM
Hi all,
Does anyone know ?
Pete.
Posted 17 May 2026 - 06:08 PM
Hi, if you Google Classic Mini Engine Specifications Guide / PDF / PISTON
It's a document from Scribd and this may help you decide the clearence required for your engine.
Posted 17 May 2026 - 06:52 PM
Posted 18 May 2026 - 04:12 PM
Thanks Chris, can't read it though, it's blurred
Posted 18 May 2026 - 06:51 PM
On the crown, the part number is stamped on it, then after or under that is a SP and some numbers stamped following that. That's the Skirt to Bore Clearance in metric and the piston is measured at 90 degrees to the Pin, 13 mm up from the bottom of the skirt.
Posted 22 May 2026 - 02:51 PM
The one I have in my hand says :
AE 21253 .020 KKD
That's all I can see.
Posted 25 May 2026 - 01:13 PM
