Permanent Live In Dash Area.
6 replies to this topic
#1 MikeRotherham
MikeRotherham
  • 1,021 posts
Posted 23 May 2026 - 05:17 PM
Can anyone recommend where I can access a permanent live in the dash or switch area to save having to run the wire back to the fuse box?
Edited by MikeRotherham, 23 May 2026 - 05:18 PM.
#2 Ethel
  • 26,568 posts
Posted 23 May 2026 - 09:30 PM
Ignition or light switches. Neither are fuse protected, so not for 2kw fan heater.
#3 Aridgerunner
Aridgerunner
  • 203 posts
  • Local Club: None
Posted 24 May 2026 - 12:55 AM
Brown wires are always hot/live.
#4 68+86auto
68+86auto
  • 1,333 posts
  • Local Club: Queensland Mini Car Club
Posted 24 May 2026 - 10:41 PM
A purple wire is a much better idea depending on what you are fitting. The purple wires are fused.
#5 sonscar
sonscar
  • 3,194 posts
Posted 25 May 2026 - 07:35 AM
Personally I would run a new fused spur from the solenoid,hardly any work really and you could also fit a new accessory fuse box at the same time.Just me,Steve,
#6 viz139
viz139
  • 720 posts
  • Local Club: Irish Mini Owners Club
Posted 25 May 2026 - 12:53 PM
What year is the Mini and what are you trying to power?
Post '92 Minis have a purple for radio and clock.
All Minis have Brown to Light switch and Ignition switch but these are high power unfused cables and best left alone.
Better to take a feed from Purple at the fuse board.
#7 stuart bowes
stuart bowes
  • 2,525 posts
Posted 26 May 2026 - 11:18 AM
interior light is another option, purple(?) wire goes up the left side A pillar.  depending what for though I'd run a new cable as well, to make sure the wire is new, and correctly rated
Edited by stuart bowes, 26 May 2026 - 11:19 AM.
