Gearbox Bearings Torque Settings
Posted 24 May 2026 - 08:38 AM
Can someone give me, in English, in nm, the torque settings for the gearbox bearings? The 3 bolts that preload the double race bearing, the pinion nut and the opposite one? No idea what they're called. My Haynes manual has basically nothing about the gearbox.
Pete
Posted 24 May 2026 - 09:42 AM
There is a whole chapter on gearboxes chapter 6.
you have more to do than just tighten bolts.
have you measured the gap and fitted the correct thickness of shims?
the main shaft retainer bolts should be 18Nm
the nuts are both 207Nm
Posted 24 May 2026 - 10:09 AM
Some versions of Haynes don't cover the gearbox.
Posted 24 May 2026 - 10:56 AM
Guessworks has a pretty thorough guide - you may have to follow the YouTube link now.
Posted 24 May 2026 - 10:57 AM
