5/16 Unc Differential Side Cover Bolts
Posted 24 May 2026 - 06:16 PM
Posted 26 May 2026 - 09:50 AM
When a friend brought me some boxes of bits and asked me to rebuild his father's engine, I said "Yes" too soon.
Apart from the studs in the block, there were no nuts or bolts, so I bought an assortment of washers, studding, nuts and locktite.
Edited by DeadSquare, 26 May 2026 - 10:00 AM.
Posted 29 May 2026 - 10:44 AM
can you not get the ones that are 1/4" too long and just cut them down. give the ends a slight bevel so it goes in the thread nicely
Posted 01 June 2026 - 07:41 PM
I always use the 1/2" AF bolts with a spring washer as fitted on all the earlier cars.
Posted 12 June 2026 - 01:51 PM
How many do you need? I should have some.
They are available new, listed as 1" long (I know there are some slightly longer clutch cover ones too):
https://www.minispar...h-end-cover-unc
Edited by GraemeC, 12 June 2026 - 01:52 PM.
Posted 13 June 2026 - 10:23 PM
3, one to replace the one with knackered threads and 2 to replace the odd ones with the sunken heads that also appear to be softer/easier to round off (yes I know no one is going to notice two of the bolts have odd heads, but my ocd will)How many do you need? I should have some.
Edited by 1984mini25, 13 June 2026 - 10:26 PM.
Posted 09 July 2026 - 02:03 PM
Sorry - just seen this.
Let me have a look in the drawers.....
Got some - pm me
Edited by GraemeC, 09 July 2026 - 02:20 PM.
