Hey guys, I’m having problems with my Mini engine I have finished building. It starts and ticks over fine, rev counter needle is steady at 800rpm and revs smoothly up to 6000rpm without any spits or splutters.
When I try to take it for a test run it bogs down as soon as I try to pull away. However, if I floor it, it pulls ok.
It’s a 1275 that was in need of a rebuild.
The spec is bored out to 1293 with 8.8cr +0.20 pistons.
SW5 cam timed at 107 degrees with a vernier sprocket as perfectly as possible using a dial gauge.
Head is the Mini Spares MSE4 35.7 inlets and 29.5 exhaust valves 21.4cc combustion chambers.
Dizzy is a Swiftune CSi with vacuum advance matched with a GCL216 coil.
Lumention silicone leads and NGK BP6ES plugs.
Running a Filter King regulator at 2.5psi via a Facet electric pump.
Carb is a used Hif44, looks like it’s from a metro. Blanked off the breather inlets parts. Overflow is clear and fitted with a tube to the air. Replaced float valve, float level set, jet is a BDL with red spring, also tried a green one, and I’ve tried several types of dashpot oil. The dashpot piston has a small approx 5mm amount of movement before resistance is felt when pushing the piston up. Spindles are a snug fit with no excess movement. Advance pipe to dizzy is fine.
All parts are new including fuel lines with the exception of the carb.
I have looked over the inlet manifold for any cracks and checked the levels with the exhaust manifold match where they bolt onto the head.
Any ideas of what I can check next would be greatly appreciated.
