1992 Mini Cooper's Roof With A Rib Around It? Big Question!
6 replies to this topic
#1 vmg
vmg
    Starting My Mini Up
  • 2 posts
Posted 01 June 2026 - 08:22 PM
Hi guys:
Please bear with me, I am not native in English and may not be using the correct words, particularly technical words....
I just bought a 1992 Mini and apparently, for some odd reason, the roof was changed for an older Mini's roof. Why? No idea.... I am hoping not because of a big body damage but perhaps because at some point it had a sunroof and somebody decided to remove it.... no idea why really.
How do I know? Because I can see from the outside a bit of the job on the poorly prepared paint job (I haven't scraped it yet) and because the interior lamp is of the older type,
Anyhow, somebody dowh here in Mexico (where we only have a few Minis), tells me that my roof is out of a Cooper as he says older Coopers used not only the channel at the end of the roof over the windshield and all around side windows and rear windscreen, but also an additional piece of metal, a sort of rib under the channel, again, all around the roof.
Can somebody tell me if this assumption of an older Cooper roof is correct or not, and if, by cutting or removing the rib and leaving the channel it would render it looking ok? I understand I would also need ot modify the roof's interior lamp area to make the newer correct type of lamp fit in there.
Can anybody shed some light?
Thanks,
Victor
#2 mab01uk
mab01uk
  • 13,038 posts
Posted 01 June 2026 - 10:14 PM
All Mk1 and Mk2 Minis 1959 -1968 (whether a Cooper or not) have a different internal roof structure as the headlining was supported on two metal frames that slide into the channel all around the roof, leaving a smooth 'rib' of painted metal below the channel exposed for a neat finish.
All Mk3 to Mk7 Minis 1969 - 2000 (whether a Cooper or not) have a different internal roof structure which has flatter sheet metal each side (over the doors/rear side windows) which has holes in to insert the six support rods/stays, which hold up the later headlining, which covers up all the internal roof metalwork and so does not need or have the smooth exposed painted metal 'rib' of the earlier Mk1/Mk2 Mini roof.
If you can post photos of your roof on the forum it will help Forum members give more detailed advice on what would be the best or easiest way for you to correct the roof and confirm what may or may not be possible.
Late Mini head-lining fitting guide- Minis Mk3 to Mk7:-
https://newtoncomm.c...inis-mk3-to-mk7
Edited by mab01uk, 01 June 2026 - 10:29 PM.
#3 Midas Mk1
Midas Mk1
  • 5,849 posts
  • Local Club: S.U.N.M.C
Posted 02 June 2026 - 02:41 PM
Its not a Mini Cord is it?
#4 mab01uk
mab01uk
  • 13,038 posts
Posted 02 June 2026 - 02:43 PM
Good point....but more details and photo of the Mini are in the owners other thread below.
Newbie With A 1992 Mini Cooper:-
https://www.theminif...92-mini-cooper/
Edited by mab01uk, 02 June 2026 - 02:46 PM.
#5 nicklouse
  • 19,046 posts
Posted 02 June 2026 - 04:14 PM
The roof skin has no relation to any of the things you mention.
i think you need to take pictures of what is concerning you.
#6 stuart bowes
stuart bowes
  • 2,609 posts
Posted 03 June 2026 - 10:41 AM
easiest way to share pics is https://imgbb.com/
don't sign up for account just use for free
copy and paste the link it gives you to a comment here and the pic will show up
#7 62S
62S
  • 1,253 posts
  • Local Club: You must be joking!
Posted 15 June 2026 - 10:04 AM
From the image that mab01uk linked to it does look to have the drainage holes and drip rails from an earlier shell - but it could be from a Mk 1, 2 or 3.
