Hi,
My 1988 Austin Mayfair 998 Auto project was bought as a non runner. I've now had it running with an electronic fuel pump but want to reinstate to the original type. Electronic pump removed, I've set up a temp fuel tank in the engine bay and am running a hose direct from this tank into the inlet on the manual pump. Turning the engine over does not show any fuel coming from the outlet on the pump. I know that a 40 year old membrane is likely to perish so I have stripped the pump down, membrane fine, and i have pumped fuel through it manually, out of car so proved it functions. I've read that it needs to be fitted at the correct side of the cam lug but how can you tell as there is only one way it goes into the block. Any ideas??
