Carb Needle Help Required
Posted 16 June 2026 - 07:01 PM
Anyways, the needle I have is clearly not letting enough fule through under load or on acceleration.
All suggestions as to what needle to try next would be a great help.
ThankAll
Bobby
Posted 16 June 2026 - 10:41 PM
Note that a misfire will cause high O2 and therefore make it appear lean to an AFR gauge which just uses an O2 sensor.
I would also check the fuel pressure during these conditions before touching the carb. The carb cannot deliver fuel it is not getting.
The carb is the last thing to touch. The mechanical, ignition and fuel delivery aspects all need to be tested first.
Posted 17 June 2026 - 06:30 AM
Has it always behaved liked this? Have you made other recent adjustments that could affect your afr readings? Is your test equipment accurate? As had been said on this site many times, there is no absolute combination of needle, damper oil/spring that you can plug in and expect to work perfectly for you, it takes some experimentation as each individual engine reacts differently. If all other tuning parameters are OK, try this site to help select a needle that is richer is the range that you want. I've had pretty good luck with it. https://www.sumidel....gory/su-needles
Posted 17 June 2026 - 07:24 AM
Ac
Posted 17 June 2026 - 11:43 AM
Great resource, thanks for posting. That's what this site is all about.
Posted 24 June 2026 - 02:50 PM
thank you Mr Dood as always you give saged advice🙏Depending on what needle you are using now, it may not be possible to find one that works for you, and it's very likely a custom profile will need to be derived for your engine.
Ac
Posted 24 June 2026 - 03:07 PM
At the moment I'm running the BBC needle shown on the graph. My AFR shows around 13.5 on idle 1100 rpm and runs around the same under load above 4500rpm however, everything in-between runs lean at around 16 to 18 on the afr.Im kinda thinking the BAM needele might be my next attempt?
Any thoughts would be welcome at this stage.
Posted 09 July 2026 - 08:13 PM
Classicminidiy on the web also has a good needle chart
Posted 10 July 2026 - 10:40 AM
Posted 10 July 2026 - 02:37 PM
Peak power is at 12.6:1, so even at what you aren't achieving full power - that said 13 is pretty good.
classicminidiy.com has a good comparison chart system which I've been using and from that it seems the BCA needle would give a richer mixture midrange.
The BCG might give you a little more low down but might end up sobberingly rich at peak power
