Horrible Rattle / Crunching Noise From Offside Front
6 replies to this topic
#1 gruck62
gruck62
  • 21 posts
Posted 18 June 2026 - 04:48 PM
Hi
My 1983 Mayfair has started making the most awful rattle / crunching noise from the offside front.
It sounds like someone has put nuts in the hub cap - they haven't !
The noise is there even when I coast downhill in neutral with the engine switched off.
I can't see anything obvious underneath.
Any ideas please ?
Geoff
#2 lsto
lsto
  • 712 posts
Posted 18 June 2026 - 05:23 PM
Have you checked the backplates on the brake disk, the brackets break and they sound terrible when they rattle.
If you have a welder a quick tack will usually sort it although a lot of people remove them if it's your problem.
Good luck
#3 Earwax
Earwax
  • 595 posts
Posted 18 June 2026 - 08:27 PM
Better to be safe than sorry.
Put it on a jack stand or two - and feel for bearing and ball joint play - take the castle nut off and ensure the CV washer hasnt cracked - allowing lots of bearing movement
( I would probably also pull he whole CV joint as they can feel fine but suffer hairline cracks :
Check tie rod ends and steering - look for missing nuts and bush failure
Lower arm pivot pin bushes
#4 Ratters
Ratters
  • 17 posts
Posted 19 June 2026 - 09:41 AM
Loose wheel nuts?
#5 ADRay
ADRay
  • 139 posts
Posted 19 June 2026 - 11:18 AM
Loose wheel nuts?
X2. Just dealt with this myself. mine sounded like a low toned rattling
#6 gruck62
gruck62
  • 21 posts
Posted 19 June 2026 - 05:30 PM
Hi  - I've checked the wheel nuts and they are fine.
Jacking her up tomorrow and have a good investigate.
I'll let you know if I find anything
#7 gruck62
gruck62
  • 21 posts
Posted Today, 03:48 PM
So I've taken off the wheel and brake drum.
As far as I can tell everything is in order and nothing obviously loose or broken.
I don't know where to look next. Possibly jack up the whole front of the car / wheels off and see if i can reproduce it !
