Autotest Event
9 replies to this topic
#1 Mudhen
Mudhen
  • 63 posts
Posted 18 June 2026 - 06:23 PM
Hello all,
Last weekend I got my '75 rally car out for a 2-day autotest style event at a farm here in the states - think I'm still learning how to get the best out of the car vs my r53 but I've only done a handful of events in it so trying to be patient.  Realistically I suppose I won't be able to compete for top times in it, whether me personally or the car, but my times were respectable, imo.  I managed a 6th out of 22 in the 2wd run group - harder to compare to the awd crowd since the courses can change some, but that put me around 12th out of 39 cars overall.
Prior to the event I noticed my outer tie bar bushes were split, so replaced with the road/rally ones from MiniSpares.  They are now gone again after just 13 minutes of runs - is this just what I need to expect when really thrashing the car in the dirt?  Currently I do have poly on the backside - I know people say to use rubber there - does that just help for braking or would it help make the fronts last longer as well?
The other issue was the heat - it was 90f and by the end of the first day the car was *almost* overheating - I was thankful we only got 7 runs.  I had an '89 with an electric fan in the wheel well but can't imagine that would last long in gravel conditions - other options?  Maybe something like water wetter?  What about removing the headlight/bucket?
Thanks gents!
Pat
#2 nicklouse
  • 19,067 posts
Posted 18 June 2026 - 08:34 PM
Very different to UK autotests.
hard to tell but looks like you are missing some washers there.
#3 DeadSquare
DeadSquare
  • 3,382 posts
Posted 19 June 2026 - 05:26 PM
A lead backed front bumper and moustache gets a bit more weight on the front wheels.
#4 Gaz66
Gaz66
  • 1,195 posts
Posted 19 June 2026 - 06:40 PM
Looks a bit like uk autocross
#5 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,741 posts
  • Name: Chris
  • Local Club: None
Posted 21 June 2026 - 04:56 PM
What size are your wheels? They look huge!
Looks like alot of fun though
#6 Mudhen
Mudhen
  • 63 posts
Posted 24 June 2026 - 10:27 AM
There are washers on them - the bushings folded out around them...so possibly what was on there was too small. Will try larger diameter ones - thx!
The wheels are 13s - they were the only gravel tires I could get - 165/65-13. I just got some 12" Black Rockets, unfortunately they are taller. They do have a 145/70-12 which i might try next when my wallet recovers. :-)
#7 Mudhen
Mudhen
  • 63 posts
Posted 24 June 2026 - 10:52 AM
Interesting about adding weight to the front, never heard that before. I've been thinking about getting rid of the huge battery the PO put in it - but it's fairly neutral right now and I was wondering if that was done specifically to keep the back in check.
#8 nicklouse
  • 19,067 posts
Posted 24 June 2026 - 11:35 AM
 Nope not what I said. There should be two on the front of each side. A cupped and a bigger flat. Looked in your workshop manual?
#9 Mudhen
Mudhen
  • 63 posts
Posted 24 June 2026 - 06:32 PM
Yes, for the torque spec. I didn't look for what I didn't know may be missing.
Maybe that's one of the best part of asking a question...or maybe it's just to make someone else feel better about themselves.
I hope I helped.
#10 GraemeC
GraemeC
  • 7,475 posts
Posted 09 July 2026 - 07:51 AM
As Nick says, you need this:
https://www.minispar...-bar-cup-washer
and
https://www.minispar...uty-flat-washer
on each side of the car
