Rear Brake Bleed Problem, Help Please
7 replies to this topic
#1 neet street
neet street
  • 40 posts
Posted Today, 11:01 AM
Hi all, went to bleed the brakes yesterday and after going all the way round (furthest away from master working round to nearest) the tested the brakes to find the fronts work well, but the rears dont work? brought a pair of new cylinders thinking this may solve the issue, but no!  Bleed through again and still no back brakes (when pushing the brake peddle down on bleeding, it will not go all the way down on the rears, but does on the front if that helps diagnose the issue)
thank you in advance for any help.
#2 ADRay
ADRay
  • 138 posts
Posted Today, 11:16 AM
what mark is your mini? to clarify, you are getting a good flow of fluid from the rears when bleeding?
#3 neet street
neet street
  • 40 posts
Posted Today, 11:20 AM
Thank you for your reply
Its a 1984 Mini mayfair, and I do get some flow when trying to bleed, but the peddle def does not go to the floor?
Edited by neet street, Today, 11:20 AM.
#4 smurfomatic
smurfomatic
  • 476 posts
Posted Today, 12:10 PM
Have the rear brakes been properly adjusted?
#5 neet street
neet street
  • 40 posts
Posted Today, 12:16 PM
Yes, all ajusted correctly... did fit a new master cylinder fitted last year, but car not used sinse. It was bleed at the time, but not tested, so maybe the problem goes further back to then?
Edited by neet street, Today, 12:42 PM.
#6 neet street
neet street
  • 40 posts
Posted Today, 01:06 PM
Could the issue be with the presure reducing valve?
#7 weef
weef
  • 544 posts
Posted Today, 03:21 PM
Rear brakes can be a pain to bleed when using the "pump pedal" method.
Either employ the use of a pressure or vacuum bleeding device to successfully bleed the rears.
#8 neet street
neet street
  • 40 posts
Posted Today, 05:24 PM
Thanks for the advise, I will give it a go tomorrow :-)
