Unusual Issue
3 replies to this topic
#1 Cooperman
  • 23,515 posts
Posted Today, 01:19 PM
Whilst doing the final preparation for my Cooper 'S' to compete in the East Anglian Classic Rally this coming weekend, I took it for a test drive and discovered a clutch issue. It felt odd and so I measured the arm movement at full depression. The top of the arm moved 0.40" and the minimum should be 0.55".
So I changed the clutch slave cylinder, with no improvement. Then I changed the clutch master cylinder, but still no improvement. If pushed down slowly it disengaged cleanly and re-engaged OK.  However, when pushed down quickly, as it will be on rally tests, the pedal was hard to depress and slow to re-engage causing a bit of clutch slip.
My thoughts were that there was a hydraulic lock caused by the flexible hose. I didn't have a spare new clutch hose, but a front brake hose has the same threads and is just a bit longer. Fitting it cured the problem, so I deduce that the internal bore of the hoe was collapsing when pressure was applied quickly.
Now it is rally-ready and my son is driving is (I am too blooming old now!).
#2 absx2
absx2
  • 954 posts
Posted Today, 03:08 PM
I had exactly the same thing happen a few years back so I replaced it with a one piece braided hose which also makes for easy bleeding but I guess you would have to keep the rubber hose for regulations.
I had two rear flexi hoses do the same, at first I thought there was an issue with the regulator valve as I couldn`t bleed the rear brakes.
Good call with the front brake hose.
#3 Cooperman
  • 23,515 posts
Posted Today, 05:21 PM
I have metal braided hoses on all the braking system and will probably change the clutch one in due course.
The regulations allow Aeroquip hoses.
#4 DeadSquare
DeadSquare
  • 3,379 posts
Posted Today, 05:36 PM
When you replace the clutch hose, remove the earth strap, drill out the connectors either end from 5/16" to 1/2" and fit it over each end of the new hose.
It makes an 'engine out' a little bit easier.
1 members, 1 guests, 0 anonymous users
    alpder
