Drilled Airbox
Posted Today, 08:13 AM
Ive recently fitted a twin box rc40 instead of a single box stainless rc40 in a bid to quiten down the car inside.
I was out last Sunday on a car run and the roar from the induction side is very loud.
I have just acquired a standard airbox with no mods to it.
Will this be better and then fit the k and n inside it?
Im not out for all out power and the engine is a 1275cc mg metro unit with spi unleaded head fited.
Thanks all.
Posted Today, 08:38 AM
The standard airbox is always going to be the most quiet option.
Any chance of a picture to see where your holes are drilled as the best place to keep the noise down is on the front underside closest to the rocker cover.
I can`t really notice any more induction noise with the smaller holes on the front underside.
Did the twin box reduce the " boom " on overrun ?
Posted Today, 08:41 AM
I have a twin-box RC40, and a drilled airbox with K&N filter (on HIF38/1275). Intake noise is negligible. Have you got pictures of your airbox?
No 'boom' on over-run. I did have to extend the exhaust tip a few inches behind the valence on my van, which hugely reduced interior noise.
Edited by alpder, Today, 09:44 AM.
Posted Today, 09:42 AM
I could just swap airboxes and see what and if theres any difference
Posted Today, 10:07 AM
Posted Today, 10:23 AM
Here's my airbox. I've cut off the inlet pipe and drilled two large holes in the side - didn't want to weaken the 'floor' of it, nor risk the holes being partly inside the filter. I've also screwed it closed with #6 self-tappers, because it won't stay clipped shut so air (and noise) leaks around the top/bottom of the filter without them.
160IMG_20260331_134811000cr.jpg 71.58K
0 downloads
Posted Today, 10:28 AM
Posted Today, 10:30 AM
Posted Today, 11:00 AM
Taking air from outside directly might cause carb icing - not all the time, but in the right humid conditions and especially at part-throttle. The modest potential power benefit doesn't seem worth the pain of adding ducting. The faster you're going the more quickly the air around the airbox is being flushed with fresh anyway, just by the force of it coming in the front.
Posted Today, 03:08 PM
Keith Calver has done lots of research on this, which I think you can find on line.
It is persuasive.
I have never suffered carb icing as a result of modifying the box.
In winter I run a hot air intake into the end of the nozzle.
Posted Today, 03:51 PM
Nor I... but OP is thinking of running an intake duct to the front grille.
Posted Today, 04:13 PM
Here we go, my current airbox. The dashpot had 3 in 1 in it but now it seems to be gone and theres hardly any resistance when I push the plunger up and down.
That one shouldn`t have a notable difference in induction noise over a completely standard airbox.
As for oil it depends entirely on your individual state of tune but I would top it up with 3 in 1 and go from there.
Posted Today, 05:40 PM
Metro filter housings are a bit better & were used on some Mini models.
All carbs will have left the factory with engine oil in their dampers. Thinner oil will allow the piston to rise faster & give a weaker mixture under acceleration. Performance tuning modifications typically require the opposite.
5 user(s) are reading this topic
4 members, 1 guests, 0 anonymous users
Chris1275gt, drydavel7, Spider, smurfomatic
